Author: Subject: water cooling
posted on 27/8/06 at 09:02 PM Reply With Quote
water cooling
my pc keeps reminding me its going over 80 degrees! I need some water cooling.
Anyone know a cheap route to water cooling? all the kits i've seen are mega expensive
RichardK
posted on 27/8/06 at 09:09 PM Reply With Quote
If it used to be alright and has just started doing this I would replace the processor fan with a like for like replacement but a better quality.
If this is a new build, check that the thermal grease is evenly covering the cpu and heatsink, (you should be able to get this from most pc shops for about a quid) and also ensure the fan is working properly and see if the mainboard has any utility that can increase the fan speed.
Hope this helps
Regards
Rich
UncleFista
Just take yer cooler off and blow it out with an airline, watercooling on the cheap is possible, but a bit overkill ?
Tony Bond / UncleFista
MattCraneCustoms
posted on 27/8/06 at 09:29 PM Reply With Quote
Hi there. Im running watercooling. Cost about 250 to do, but I did it in a new PC built from scratch. temp. usually around 25 degrees usually. Check this baby!! Rescued attachment DSCF1906.JPG
Confused but excited.
posted on 27/8/06 at 10:06 PM Reply With Quote
This is the Locost Builders Forum.
Build a water cooling system.
Aquarium pump.......
rjbrookes
posted on 27/8/06 at 10:08 PM Reply With Quote
try this
http://www.lancerregister.com/showthread.php?s=&threadid=122456
miserableoldgit
posted on 27/8/06 at 10:34 PM Reply With Quote
Linky
I use this on 2 PC's and they keep the temp down to 50 degC no problem. I wouldn't pay more than £40 bnib though, less for 2nd hand
Youth and vitality are wasted on the young
JackNco
posted on 17/9/06 at 12:55 AM Reply With Quote
Depends what sysem you are using but watercooling is still only raly needed for over clockers.
If you want a cheap way of doing it its possible to fill seal up a computer case and fill it with vegetable oil...
It works and its cheap.... toms hardware did it
John
posted on 17/9/06 at 08:34 AM Reply With Quote
You can build a car for that ! Clean the case out, get rid of the dust in the cooler and make sure there is a decent case fan fitted. I scrape the gunk off the cpu & cooler base and use a blob of Arctic Silver on there, it transmits the heat better.
