se7ensport
posted on 29/8/06 at 03:57 PM |
Another 2.0 pinto question - normal opperating temp?
It has been suggested that mine is a little on the low side, shows approx 75 degrees on gauge.
I don't think this is quite right either and now wondering if either guage is inaccurate or therostate is wrong or not functioning properly.
As a second question does anyone have a good tip for cleaning the mank out of the cooling system (products or washing up liquid..)? my header tank is
orange on the inside and i've flushed the system till it runs clear but the rusty coloured stains remain.
Alex
posted on 29/8/06 at 04:12 PM |
^^^^ all the above.
you need to measure the temp and see if that is what the guage shows, if not you need to investigate:
- if gauge is electrical, is sender correct for the gauge?
- is sender /guage faulty?
- is thermostat correct?
- is thermostat working properly - test in saucepan of hot water
you don't mention the conditions - is the fan (assume it's electric) on all the time?
- what control the fan to turn on and atwhat temp?
you need to get a thermometer and start measuring.
re: mank; I used halfords 2 part radiator cleaner; don;t have any bad to say about it but locost is to put a couple of teaspoons of caustic soda, run
till hot, then drain and flush.
UncleFista
posted on 29/8/06 at 05:07 PM |
I've heard of people using bio soap powder (Persil etc) to clear out the waterways, just run up to temp, wait to cool then replace with your
normal water/antifreeze mix.
Tony Bond / UncleFista
se7ensport
posted on 29/8/06 at 06:02 PM |
^^^^ all the above.
fan is electric and goes on and off keeping it at 75ish, correct sender, I think it could be the connection. I'll get hold of a thermometer and
check- what temp should it be???
ps I'll try some persil, works on my jeans ![](/images//smilies/wink.gif)
DarrenW
posted on 30/8/06 at 01:08 PM |
Firstly flushing. I disconnected the pipes off my Pinto after the water was well brown and muddy. i flushed from several direction with plain water
and hose pipe for approx 1.5 hours till it ran clean. Since then it has been fine so you may not need flush agent. There was a blanking plug in the
block for the water jacket, i removed it and no water came out! i had a probe about with small scredrive and wire and eventually it ran through.
Apparently this can happen if years ago a past owners didnt use correct antifreeze.
If you do need some flush agent id go for proporietery product rather than soap powder (only as ive never heard of that being used before). Forte do
one which is apparently v.good. TBH i dont see why saop powder wont work as long as its flushed out well. I do wonder though if it can have an adverse
affect on the antifreeze if its not removed. I dont think its easy to remove fully with cold water.
Ref temp, it does sound low. Firstly check the sender and gauge are matched and working well. If it is then i suspect it is running well cool. Do you
have thermostat? Is fan switch in rad correct? My Pinto runs at around 94, fan switches in at 97. On the track it gets above 100 and still runs fine.
Dont forget when comparing your temps to others that different gauges and sender locations will give different results. Im using DD2 with matched ETB
sender in the std Pinto location (above dizzy).
There is a train of thought that if an engine runs too cool the condensation in the oil wont be boiled off and could affect engine wear etc so its
worth getting it right.
Oh - just thought, i did read somewhere that dishwashers are good at cleaning out header tanks. Probs best to do it without the dishes in!!
ady8077
posted on 30/8/06 at 07:17 PM |
Hi
I've been having probs with my pinto running a bit hot, gave the cooling system a good flushing and put new antifreeze in and now runs about 95
deg C
75 must be a faulty guage/sender, what thermostat have you got? mines 88. Does your top hose get hot?
Adrian
Toady1
posted on 31/8/06 at 06:55 PM |
on route to sva mine was between 95 and 105! im going to check my stat is opening fully!
