Author: Subject: Pedal plans
pathfinder
posted on 3/9/06 at 10:30 PM Reply With Quote
Pedal plans
Hi Gents
Has anyone got any plans for a pedal box, sketches, dimensioned photos, anything!
It’s next on my list of things to do and I quite fancy making my own.
I have tried searching the boards but no joy!
Thought there was a tread for the Dax pedal box a while ago but can’t find it anymore!
Any info would be much appreciated
Thom
robertst
posted on 3/9/06 at 11:10 PM Reply With Quote
rallydesign has a section regarding the ratios to use... pretty useful imo. with that and the measurements from a standard sierra box, u should have little problems doing a custom pedal box
go to rallydesign.co.uk then online shop and on the right, where it says "tech tips" there's a section called pedal ratios/mechanical leverage.
Tom
timmy
posted on 4/9/06 at 01:52 AM Reply With Quote
Thom,
I designed my own floor mounted pedal box to suit Toyota brake and clutch m/c. I can email you the dwgs if you like.
PM me your email address and I'll send them over.
Tim
Danozeman
posted on 4/9/06 at 06:58 AM Reply With Quote
Have a look in my archive mate. Theres 3 piccies down the page labelled pedals. They may be of use. I didnt work out any ratios, i just made them to see what they came out like. They look nice and as luck had it the ratios seem to be perfect. (makes a change i get some luck).
They are all seperate pedals/brackets bolt through the floor with a strengthening plate.
Dan
