Author: Subject: nose cone atachment
Maradona
posted on 6/9/06 at 05:07 PM Reply With Quote
nose cone atachment
How can I atach the nose cone, any ideas.
Maradona
posted on 6/9/06 at 05:14 PM Reply With Quote
bolts through the return flange of the nosecone into rivnuts in the top chassis rails
Humbug
posted on 6/9/06 at 05:17 PM Reply With Quote
I don't have a rivnut tool so I have bolts through the top side rails, plus a bolt underneath the goes into a tab from the bottom front rail.
Other have put hinges underneath
[Edited on 06.09.2006 by Humbug]
Maradona
posted on 6/9/06 at 05:25 PM Reply With Quote
Any pics ??
Maradona
posted on 6/9/06 at 06:17 PM Reply With Quote
Phone number
If U have serius intentions I can give the number of one of my sisters in my avatar.
Maradona
the hand of good
[Edited on 6/9/06 by Maradona]
Guinness
posted on 6/9/06 at 06:35 PM Reply With Quote
I have a bolt on each side, through the return on the fibreglass into a rivnut on the top rail of the chassis and a pair of hinges on the underside of the front rail / back of the nose.
Hinge Indy Nose
Hinge Indy Nose
Allows me to hinge it forward for maintanence.
Hope that helps.
Mike
timmy
posted on 6/9/06 at 09:51 PM Reply With Quote
I've used Dzus fasteners on mine. 2 under the chin and 2 either side of the rear (where the bonnet will go).
Seems to fit nicely.
The book shows you how to do this IIRC
shades
posted on 6/9/06 at 10:47 PM Reply With Quote
I used 3 dzus fasteners. Also used rivnuts in other places and fitted with the homemade tool shown here:
Homemade rivnut tool
Worked really well...
Adrian
Marcus
posted on 7/9/06 at 12:11 PM Reply With Quote
I've done the hinge thing as described above. Makes filling water sooooo much easier. Mine's not fixed at the rear - no need, the bonnet holds it down.
Marcus
Because kits are for girls!!
The Doc
posted on 7/9/06 at 08:28 PM Reply With Quote
I found the Dzeus fasteners to be a pain in the arse so I chopped the bayonet bits off, kept the countersunk plate and put a nice c/sunk stainless machine screw into a plate welded to upper chassis rail. This way you don't eat away at the GRP every time you turn the bolt. Lovely result but a bit pricey!
