theconrodkid
posted on 9/9/06 at 05:22 PM |
copper pipes
i was wondering how i could make a ridge on the copper fuel pipe to stop the rubber pipe being blown off.
i got some olives and an 8mm male/female union,cut a slot in the female nut (took 1 side of the hex out) to slide over the side of the pipe,insert
olive,tighten union,remove union,slide nut off of pipe and bingo
blue peter badge please
who cares who wins
pass the pork pies
rayward
posted on 9/9/06 at 05:29 PM |
i tried that, and it didn;t tighten up correctly, it spread the nut.
i ended up using the fitting "as is", then cutting the nut off with a dremel afterwards.
another option is to get a steel ball bearing, and hit it into the end of the pipe to flare it.
Ray
omega 24 v6
posted on 9/9/06 at 05:32 PM |
Or you could get a solder ring fitting and put it on.
auzziejim
posted on 9/9/06 at 05:41 PM |
i just used the 1/4" flare on my brake line flaring tool kit. nice and easy
lexi
posted on 9/9/06 at 06:52 PM |
Solder the olive on.
Alex
Dusty
posted on 9/9/06 at 10:33 PM |
Even cheaper, solder half the olive on!!!
theconrodkid
posted on 10/9/06 at 02:45 PM |
anyway,i,m well pleased,all mounted up and throttle pedal actually does something now
who cares who wins
pass the pork pies
