Author: Subject: GRP or plastic VS heat
dmottaway
posted on 14/9/06 at 01:26 PM Reply With Quote
will GRP or Carbon Fiber withstand the heat if used for an intake manifold?
Might be easier to use than aluminum for my GSXR TB's on a 4age head.
any ideas?
dave
Somewhere, in Texas, a village is missing its idiot.
Kissy
posted on 14/9/06 at 05:06 PM Reply With Quote
Should do - it works ok on a lot of modern cars. They use injection moulded polymers, typically with a glass filler for stability & strength. It'll be a complex tool if you intend to make a 1/2 decent job
stevebubs
posted on 14/9/06 at 07:29 PM Reply With Quote
Hm...wouldn't use GRP post-injector even with epoxy resin.
CF - probably ok?
Can't believe it's that hard to get 4 pipes welded to a flange....
Syd Bridge
posted on 14/9/06 at 08:21 PM Reply With Quote
[quoteHm...wouldn't use GRP post-injector even with epoxy resin.
See my post on the other thread of the same name.
Have a lookunder the bonnet of any modern professional racecar, and quite a number of production cars.
Plastics and composite intakes by the dozen.
Aluminium will be quicker and cheaper though. No plugs and moulds to make.
Syd.
