Tiger Super Six
posted on 28/9/06 at 09:31 PM |
Type 9 Electronic Speedo Sendor
Does anyone know whether you can use the electronic output on a type 9 gearbox in connection with the Tiger electronic speedo (ETB Gauge)?
There are three wires out of the type 9 electronic spedo sender, but only two to the speedo.
The speedo uses a read switch to pick up on pulses but the bit in the gearbox is a cog, although it must have something inside it which might be
magnets and a sensor?
Any ideas?
Mark.
Mark
Tiger Avon
mookaloid
posted on 28/9/06 at 09:40 PM |
give etb a call - they are bound to know
RazMan
posted on 28/9/06 at 10:37 PM |
Not sure about the colours but the three wires on the sensor will be +ve, earth & signal. The two wires on the speedo will be signal &
earth............ probably.
Raz
Tiger Super Six
posted on 29/9/06 at 09:11 AM |
Spoke to ETB this morning and they confirmed that the three wires on the sensor are +ve, earth & signal.
This can be wired into their dial.
Mark.
Mark
Tiger Avon
Dusty
posted on 29/9/06 at 12:39 PM |
I'm using one with my VDO speedo. Works fine.
irvined
posted on 29/9/06 at 01:54 PM |
Quick hijack
Anybody used these with a telemetrix speedo, might be worth while giving this a try rather than messing around with the magnets (AGAIN)
http://irvined.blogspot.com
