New Topic New Reply
Author: Subject: Frame dimensions
mrpaul40
posted on 2/1/02 at 12:04 PM Reply With Quote
Frame dimensions
I am proposing to install a 2L Toyota 3SGE engine and Toyota Supra gear box. Can anyone please help me outwith the location of tubes G1 and G2 on tube C and the location of tubesl and m on tube C for the transmission tunnel
Dunc
posted on 5/1/02 at 12:49 AM Reply With Quote
What I'd suggest is to build up your chassis to the point of the transmission tunnel. And assuming you already have the gearbox and engine, place the gearbox in it's relative position within the chassis, then get your seat or cussion or whatever and sit in the normal driving position in the chassis and move the gearbox until you feel comfortable changing gears and it's not intruding too much into either footwell.
Then marking off and measuring where the tubes will sit, making sure there's still room for the engine in the front, and build the transmission tunnel round the gearbox and propshaft.
You don't want to finish the car then realise that you can't get it into 3rd without leaning forward.
Dunc.
ChrisW
posted on 7/1/02 at 05:54 PM Reply With Quote
Have a look at my links section - one of the sites has a very good set of 3D drawings of the Locost which may help you.
ChrisW
zilspeed
posted on 31/5/10 at 05:03 PM Reply With Quote
ChrisW
That link, does it still work ?
jossey
posted on 2/6/10 at 03:03 PM Reply With Quote
http://www.locost7.info/files/chassis/Chassis_Sierra.pdf
hope that helps
New Topic New Reply
