New Topic New Reply
Author: Subject: MK pedal fitting???
andrews_45
posted on 7/10/06 at 03:40 PM Reply With Quote
MK pedal fitting???
MK welded the brackets to suit 'MK Pedals' on my chassis when they made it for me. I have the pedals supplied from MK, but for the life of me I cannot see the logical way of mounting them
I am guessing that there should be some bushes in the big holes??? If so does anybody know what they are off?
Does anybody have some pics so I can get my head around it?
Here's what I have...
And here are the brackets welded in place...
PS. ignore that pedal already fitted its of another car
whitestu
posted on 7/10/06 at 04:07 PM Reply With Quote
Looks as though you are missing the bushes.
MK should have supplied hard plastic ones to go into the tube on the pedals.
You then bolt through the brackets welded to the chassis.
You'll also need to make up some brackets to act as pedal stops.
Stu
pawgrp
posted on 7/10/06 at 04:43 PM Reply With Quote
You are indeed missing a set of bushes. Ring Baz on mon morning and clarify wether or not you ordered them and didn't get them or just didn't order them because u didn't know they were available.They are usually in stock.Hope this is of help.
andrews_45
posted on 7/10/06 at 04:59 PM Reply With Quote
I have managed to find the bushes, they were in a box in my garage.
The brackets seem a bit far back not much room for pedal movement
zxrlocost
posted on 7/10/06 at 05:19 PM Reply With Quote
the pedals should be leaning quite a bit forward
Jonte
posted on 7/10/06 at 05:59 PM Reply With Quote
I took the bottom one as the break pedal
Click it
andrews_45
posted on 8/10/06 at 03:20 PM Reply With Quote
any chance of seeing what the whole assembly looks like? Ta
DIY Si
posted on 8/10/06 at 05:27 PM Reply With Quote
Plastic bushes? Are these a recent thing, as mine has metal bushes.
Sun Tzu, The Art of War
andrews_45
posted on 8/10/06 at 06:55 PM Reply With Quote
I got em about 2 month ago
jacko
posted on 8/10/06 at 07:51 PM Reply With Quote
Hi mine are plastic bushes and the car is nearly 3 years old Jacko
andrews_45
posted on 8/10/06 at 10:30 PM Reply With Quote
Does anybody have any pics I can see pls?
Jonte
posted on 9/10/06 at 07:00 AM Reply With Quote
I´ll take a hike to the garage and try to take a pic of them
Click it
andrews_45
posted on 24/10/06 at 04:40 PM Reply With Quote
did you manage to take those pics by any chance?
mackei23b
posted on 30/10/06 at 11:09 PM Reply With Quote
Hi there here are a couple of pics from my MK Indy
mackei23b
and one more with a pedal and the bush
New Topic New Reply
