Author: Subject: Cortina/Escort/Capri front hubs' bearings
mstepien
posted on 11/10/06 at 09:39 PM Reply With Quote
I've found yout that my hubs are probably not from Cortina (the inner bearings are too big for the axle stud). So for the sake of my knowledge, do you know what are the dimensions of bearings for front hubs (inner and outer) for Cortina, Escort and/or Capri 2.8 ?
Best regards,
Michal
omega 24 v6
posted on 12/10/06 at 11:39 AM Reply With Quote
Quenton Hazell lists the following
Mk1 escorts QWB113c except mexico and rs2000 which are Qwb 114c
MK2 escorts are QWB115c except rs2000 which are QWB114c
Cortina MK3 4 and 5 are QWB115c
Capris are all QWB114c except the 3ltr v6 from 11/71 to 8/81 these are QWB416.
This doesn't help you with sizes but it's a start with the info you might need.
Someone else may know if the hubs are the same throughout the range and only the bearings are different.
