<<  1    2    3    4  >>
Author: Subject: Warner R4 Build Diary
cloudy
posted on 24/10/06 at 01:37 PM Reply With Quote
This project has now significantly changed (see below) from the early design, see the latest pages for the new project...
More information/vids available at: www.wr4.co.uk
[Edited on 27/2/09 by cloudy]
[Edited on 19/5/09 by cloudy]
[Edited on 8/6/09 by cloudy]
www.warnercars.com
cloudy
posted on 24/10/06 at 02:07 PM Reply With Quote
A few mock ups of front end shapes, it always almost looks better without it at all
FUORISERIE, you mentioned you would do the front a bit differently any suggestions?
ideas + drawings welcome!
www.warnercars.com
FUORISERIE
posted on 24/10/06 at 02:50 PM Reply With Quote
ok, send me a few 3/4 front and rear view and a side wiew image, for my rough sketches.
I tend to agree with you, it does look better with the steel tubes showing...
I will try .....but the concept looks really good, will see what i can do for you.
[Edited on 24/10/06 by FUORISERIE]
dr-fastlane
posted on 24/10/06 at 04:21 PM Reply With Quote
That is a really “cool” buggy which you building. If I can do a suggestion for the front of the car. Perhaps its an idea to bend the top tube from the nose round out of one tube, if you understand what I mean. It keeps the front of the car simple but smooth.
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
thomas4age
posted on 24/10/06 at 06:54 PM Reply With Quote
Looks very nice when it's this low to the ground, what ground clearance are you goin to run?
also not clear to me is what are you going to do with the diffcradle it looks like it's only attached to the rest of the chassis with 4 horizontal tubes? shouldn't that be braced very well?
grtz Thomas
btw nice project and should be quick aswell!
If Lucas made guns, Wars wouldn't start either.
cloudy
posted on 24/10/06 at 07:05 PM Reply With Quote
diff mounts are not made yet, don't worry far more framework to surround it yet.
I like that design, i'll try it with photoshop
Ground clearance wise I will run about 120mm. I have 2x tiny 600kg electric rams, it would be quite cool to make a system to raise the front right up for speed bumps - then I could run more like 100mm
Fuoriserie some plan views for you:
James
www.warnercars.com
cloudy
posted on 24/10/06 at 07:15 PM Reply With Quote
I'm really keen on that design dr fast lane - here's it in tubing
www.warnercars.com
Doug68
posted on 25/10/06 at 12:31 AM Reply With Quote
Front tubes.
Have you built a stress model in the computer yet or a scale balsa model of the thing?
300kg is a very ambitious goal and I would guess you’re trying to work out where the
tubes need to be to be effective rather than just what looks good.
If you keep at it long enough you should be able to make it work and look good at the same time.
Doug.
cloudy
posted on 25/10/06 at 01:28 AM Reply With Quote
It's a good suggestion - i've tried a few bits of force analysis software to model it - but all go way over my head, and I just dont' havce the time to learn how to use it properly. I've just been using common sense and judging myself how the forces are likely to propagate
James
[Edited on 25/10/06 by cloudy]
www.warnercars.com
Doug68
posted on 25/10/06 at 06:17 AM Reply With Quote
If the software is a mystery to you then build a 1/8th scale model of the frame using 1/8" square balsa and model glue.
Then pick it up and twist the thing.
Make another model of a cube X braced on all 6 sides say 100mm square and compare the 2 models.
Keep modifying your model until you are hard pushed to tell the difference between the 2 models.
Remember if your chassis is not stiff (which is different to strong). All the carfully worked out suspension geometry will go out of the window.
It may seem that this sort of stuff takes a lot of time when you could be welding things together, but I expect like me you want to make the best vehicle that you can.
Doug.
iank
posted on 25/10/06 at 07:43 AM Reply With Quote
Agree completely, a balsa model gives a really good idea of how stiff your chassis is, and is far more intuitive than a computer simulation. Takes an evening, and you get to bore your mates with it . If you need/want a number the FEA can be done later to confirm.
It's amazing how one tube can make a huge difference, it's not something that can be done by eye, at least not until you've done a few.
See this thread:
http://www.locostbuilders.co.uk/viewthread.php?tid=53918&page=1
Buggy looks really good so far BTW
[Edited on 25/10/06 by iank]
cloudy
posted on 25/10/06 at 08:11 AM Reply With Quote
OK I shall give the model a go
FUORISERIE
posted on 25/10/06 at 03:27 PM Reply With Quote
This was a personal project of mine, that due to time and work constraints I never came around in building it...., i
I couldn't build it myself, so why not have someoneelse try instead!.
Having seen your chassis, i thought about adapting my original design to your chassis setup.
this is just a very rough 10 min. sketch, but will be more detailed later in the process.
Let me know what you think, and if you like it?
[Edited on 26/10/06 by FUORISERIE] Rescued attachment img584.jpg
cloudy
posted on 25/10/06 at 04:22 PM Reply With Quote
I love it, especially the nosecone area, You'd need to be pretty handy with fibreglassing!
PS: the "final" design for mine...
ettore bugatti
posted on 25/10/06 at 09:05 PM Reply With Quote
Looks cool,
I think with some extra tubes diagonal placed. You would end up with something much stronger.
What is the width of the interior and how much is the track f/r?
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ettore+bugatti 's Aim   ettore+bugatti 's ICQ status This User Has MSN Messenger   ettore+bugatti 's Yahoo
FUORISERIE
posted on 26/10/06 at 09:49 AM Reply With Quote
Actually i think you wouldn't need much work for the nosecone,....... but I like your new bare bones chassis, maybe it looks better without the body panels....
So no need for it, keep it simple as you have done.
cloudy
posted on 26/10/06 at 10:55 AM Reply With Quote
I was thinking of perhaps redoing the chassis when I got bored, and i'd like to loosely base the design on this:
Big problems are going to be making the panels, and getting glass to fit that...
James
iank
posted on 26/10/06 at 11:19 AM Reply With Quote
Now that would be a big job.
If you are serious pick the glass first - wander round a big carpark to find something.
The front end looks a bit like the WLR, so getting a nose from them might be a good start for a buck.
[img][/img]
cloudy
posted on 26/10/06 at 11:54 AM Reply With Quote
you might be onto something - the elise glass looks similar!
Dick Bear
posted on 29/10/06 at 05:18 AM Reply With Quote
Creative juices...
There's nothing like seeing 10-minute sketches that look like auto design museum pieces, custom design frames that sit low and stable between the wheels or a group of visionaries throwing out top-notched suggestions for the benefit of everyone to get the Creative Juices flowing!
Just two pages into Cloud's build and there's already been more helpful suggestions and imaginary response than some sites receive in a year!
Great start, Cloud! may I suggest aluminum, hand-shaped body panels? Sure would be weight reducing,
Dick Bear
www.marketpointproductions.com
dr-fastlane
posted on 30/10/06 at 07:33 PM Reply With Quote
The final design is great looking Cloudy!
I would not put on too much bodywork. The chassis has an raw and racing look, keep it that way. Perhaps it sounds funny but way not copy the looks of a RC model (toy) buggy. Something like this, but with a glass front window, polycarbonate side windows (like most sevens) and some cycle wings.
ZEN
posted on 30/10/06 at 09:32 PM Reply With Quote
For me less is allways more and I like toys for big boys
My YouTube channel Cars, bikes - track days, motorsport, sim racing and more.
cloudy
posted on 30/10/06 at 09:50 PM Reply With Quote
Dick Bear
Sounds good, I think i'll follow everyone's suggestions and keep panelling to a bear minimum, except where requiured to keep away debris, to help the shape or to improve aerodynamics..
When the chassis is finished (soon) I'll throw it up to the excellent talent here for some pointers
PS. dr fastlane - exactly the sort of car I was drawing inspiration from, definately a boy's toy!
James
[Edited on 30/10/06 by cloudy]
cloudy
posted on 1/11/06 at 11:16 AM Reply With Quote
I've posted the below in the chassis section, but included it here as you midy guys probably are used to more weight over the rear suspension.
OK I've welded the rear shocks on, it gives about 1" ground clearance with the bumps fully compressed and 2" as it starts to hit the stops
This gives just over 10cm of suspension travel, with the car resting at about 6cm, leaving 4-5cm of upwards travel.
am I going to get away with this based on the photo + measurements above or do I need longer shocks?
James
[Edited on 31/10/06 by cloudy]
[Edited on 1/11/06 by cloudy]
Doug68
posted on 1/11/06 at 12:02 PM Reply With Quote
This is a hard question to answer. But I'd think you'd want 2" at least of clearance at full bump. From reading the book a typical locost has ~5" of static clearance and ~2" of travel from there to get to full bump.
More of a worry to me would be having the shock laid over that far. Effectively the suspension will get softer as its compressed, which if anything is the reverse of what you want to happen. I'd get the shock as upright as possible.
Also I'd not want to put the load into the middle of the tube like that at the top end, hopefully you're planning bracing on it?
Similarly at the lower front wishbone point I'd want that braced, I guess I assume that theres going to be a lot more bracing everywhere?
But I'm possibly too worried about that sort of thing, after all I've been tinkering with my design for over a year now and still not got a single weld done.
Doug.
<<  1    2    3    4  >>
