Author: Subject: R1 Start Cut-Off Relay Bypass...
Winston Todge
posted on 31/10/06 at 06:53 PM Reply With Quote
I'm just doing some tidying up of the loom and thought about the shorting of the clutch switch and stop switch etc... Why can't the Blue/White wire from the starter cut-off relay just be grounded rather than piddling about with other parts of the loom?
This would mean the Blue/White wire going to the Start relay would always be ground and therefore when 12V was applied to the other side of it, it woulc turn over. I've tried it and there's no problem.
I'm just curious as to whether anyone else has tried this? There's nothing I've missed on the ECU side of things to stop it running correctly is there?
R1 Relay Bypass
R1 Relay Bypass
Ta,
Chris.
[Edited on 31-10-06 by Winston Todge]
chockymonster
posted on 31/10/06 at 08:07 PM Reply With Quote
I've done it the other way round and run the blue/white wire to my Starter button. The other side of the starter button goes to ground.
Winston Todge
posted on 31/10/06 at 09:41 PM Reply With Quote
Are you using the R1 fuel pump and relay Paul?
Chris.
TimC
posted on 1/11/06 at 07:28 AM Reply With Quote
You're probably too far down the track for this, but I'm planning on not using the R1 relay assembly and using a Lucas Starter Solenoid instead.
Can't imagine that it could get any simplere than that.
smart51
posted on 1/11/06 at 08:29 AM Reply With Quote
Yes, just take the blue/white wire from the starter relay to ground. All the other stuff is to prevent bikers from starting when in gear on the side stand and then dropping the bike.
chockymonster
posted on 1/11/06 at 11:26 AM Reply With Quote
Chris.
Yep,
The engine can start without the car loom being powered, I haven't connected the car and bike looms at all and can't see any reason to.
smart51
posted on 1/11/06 at 11:50 AM Reply With Quote
Originally posted by chockymonsterThe engine can start without the car loom being powered, I haven't connected the car and bike looms at all and can't see any reason to.
You will want the ignition to be off when the key is off on both looms. Both the ignition coils and headlights need to be off when the key is off.
NS Dev
posted on 1/11/06 at 12:51 PM Reply With Quote
surely you can have headlights on with key off??
Not read anything in the bible about that one
chockymonster
posted on 1/11/06 at 01:53 PM Reply With Quote
FIA Cutoff switch is my main key
