Author: Subject: Sticky foam tape
miserableoldgit
posted on 9/11/06 at 11:43 PM Reply With Quote
Sticky foam tape
I'm trying to source some black "Nitrile like" foam about 50mm wide by 5mm thick to stick on top of the body sides and nosecone as an insulator between these and an aluminium bonnet.
Has anybody got any ideas of where I could get something like this?
Youth and vitality are wasted on the young
RazMan
posted on 9/11/06 at 11:46 PM Reply With Quote
I found something similar in B&Q - 50mm black sponge tape which I used as fuel tank strap padding.
Raz
miserableoldgit
posted on 9/11/06 at 11:54 PM Reply With Quote
Sticky Foam Tape
B&Q? That well known Locost supplier; never thought of them!
Was it fairly dense or like Aero?
givemethebighammer
posted on 9/11/06 at 11:55 PM Reply With Quote
foam Rubber strip
http://www.vehicle-wiring-products.co.uk/VWPweb2000/fasteners-2/fasteners-2.html
RazMan
posted on 10/11/06 at 12:02 AM Reply With Quote
Closed cell but I would class it as medium density - worked for my fuel tanks though.
Raz
chockymonster
posted on 10/11/06 at 12:50 AM Reply With Quote
There are probably cheaper places but I got mine from this guy
http://stores.ebay.co.uk/all-and-sundry
dave r
posted on 10/11/06 at 06:29 AM Reply With Quote
woolies
ordering some stuff this week
zetec7
posted on 10/11/06 at 07:12 AM Reply With Quote
If you have any scuba-dive supply shops in your area, they use very nice closed-cell neoprene for wet suits, and often have strips of scrap...
http://www.freewebs.com/zetec7/
Danozeman
posted on 10/11/06 at 08:16 AM Reply With Quote
I got mine from woolies trim having searched for months to find some locally with no success.
Dan
posted on 10/11/06 at 08:21 AM Reply With Quote
woollies - they do lots of this in various thickness 3 mm, 6 mm in 25 mm width and then wider and thicker stuff.
the 3 mm, 25 mm should do ya.
paulf
posted on 10/11/06 at 09:45 AM Reply With Quote
I used some Armaflex tape i found at work. It is used for lagging refrigeration pipes etc and is closed cell neoprene. If you have a local industrial refrigeration company it may be worth trying them. They also use it in sheet form about 20mm thick , this is ideal for padding seats etc.
Paul.
miserableoldgit
posted on 10/11/06 at 01:38 PM Reply With Quote
Sticky Foam Stuff
Thanks all, plenty of choice there for me to go for. Woolies is an unusual one, will most certainly investigate that one. Coming from the Black Country we are about as far away from the coast as it is possible to be in this country, and our waterways only come up to your waist, so Scuba Diving shops are a bit thin on the ground - but like the thinking, that type of material would be ideal. Might make a bid for Steve Irwins wet suit on Ebay, only one hole in it and shouldn't be a problem.
DarrenW
posted on 10/11/06 at 10:12 PM Reply With Quote
Mac#1. They are the one stop shop for all LSIS bits.
