Author: Subject: another speedo calibration problem
perky 91
posted on 13/11/06 at 10:01 PM Reply With Quote
help please
have a smiths classis mechanical speedo, in a locost with 2 litre pinto, 5 speed with 15 inch wheels, took it out at weekend (on private land of course!) and the speedo showed faster than it felt. im guessing you have to calirate it but have no instructions and no idea please help
Chippy
posted on 13/11/06 at 11:11 PM Reply With Quote
You will need to have the clock recalibrated by specialist. Try the web site for "Speedy Cables" which explains what is required, and they will alter your clock so that it reads right. hth Ray.
Danozeman
posted on 14/11/06 at 06:41 AM Reply With Quote
Try speedy cables as Ray said mate. It tells you on there website what to do.
YOu have to make an arrow to put on the speedo end of the cable. make the bottom of the tyre and ground. Push car along so the arrow makes 10 revolutions then measure how far the wheel has travelled. Send your speedo along with this info to them and theyl set it up.
speedy cables here
[Edited on 14/11/06 by Danozeman]
Dan
perky 91
posted on 14/11/06 at 07:29 PM Reply With Quote
thanks very much
just as i thought i was all sorted out
John Bonnett
posted on 15/11/06 at 08:53 AM Reply With Quote
I've just had the form from Speedy Cables. Will try to attach it.
John
