Author: Subject: transit van rear diff and axle??
goodall
posted on 15/11/06 at 10:48 PM Reply With Quote
transit van rear diff and axle?? could this be used for the rear drive, simple and like the book or would it be too wide.
i know the RS2000 used a shortend verison of the one that was in production when it came out
posted on 16/11/06 at 12:21 AM Reply With Quote
5 stud wheels and agricultural weight might be a couple of drawbacks.
timmy
posted on 16/11/06 at 02:19 AM Reply With Quote
And a crappy choice of ratio's (unless you can sub in an Escort/Corty centre)
Danozeman
posted on 16/11/06 at 06:57 AM Reply With Quote
Tranny axles are v heavy and as said 5 stud. I would stick with the cortina/escort/capri.
Dan
NS Dev
posted on 16/11/06 at 09:36 AM Reply With Quote
some very good diff ratios from early transit axles though! Can't remember which ford car axles they fit though, think it is the atlas but not sure.
think the 5.1:1 is a transit ratio, much used on forest rally cars.
ecosse
posted on 16/11/06 at 02:21 PM Reply With Quote
The RS2000 I think used a shortend version the the Atlas used in the big capris of the time, not sure if it is the same casing as used in the transit or not?
If it is the Atlas there are just about any ratios you could ever want for still available.
It was the axle of choice for rally applications, although may (as stated) be overly heavy for a lightweight 7.
Alex
