cymtriks
posted on 7/6/03 at 09:47 PM |
Ultima chassis mods
A very interesting link regarding mods to the Ultima chassis
http://www.ultimav12.ca/
He's right as well. The Ultima with roof 3300 and without probably
2000 (approx).
The Ultima chassis is actually within striking distance of a
reasonably well designed ladder frame.
The problem is that big wide enginebay.
Note from the site that adding an X brace to the top of the engine bay and a frame work across the bottom (the alloy panel is probably irrelevant to
the stiffness) give big gains.
Basically these two mods remove most of the flex in the rear of the frame.
Adding a fancy floor of honeycombe does little. No surprises there. Welded in steel is probably the best floor compromise at home build level as it is
a lot less prone to
dropping out like a riveted floor can sometimes do and does add to other, important, structural issues.
Bracing the frames over the transaxle help. Again no surprises. This is actually the first thing I'd do to an Ultima chassis. This mod also
helps locate the rear suspension better , one side to the other.
The big puzzle for me is the difference that little tube at the front makes. I'll have to have a think about this. It's got me
interested.
The stiffness of the Ultima is out. I thought it wasn't much better than a decent seven type chassis but never dared say because I didn't
think anyone would believe me.
Mark Allanson
posted on 8/6/03 at 03:30 PM |
Purely from a structural analysis point of view, try to get a look under the underside of the new Audi A4 cabriolet.
There are 2 what only can be described as farmers fence straps bolted underneath. they are about 1.5" by 3/8" wrought iron bar and run
from the inner front subframe mounts, bolted regularly right up to the rear of the boot floor (almost the length of the car). I took them off to
replace the exhaust after a rear end shunt and the front doors wont open without them!
Vorsprung durcht technik - more like agricultural bodge technik - I am totally disgusted with the brand - absolutely primitave
I any of us presented a car like this for the SVA we would be told to wee off and stick to making wheel barrows!!
Alan B
posted on 8/6/03 at 04:26 PM |
quote: Originally posted by Mark Allanson
.........Vorsprung durcht technik - more like agricultural bodge technik ..........
ROTFLMAO......
Classic..
Mark Allanson
posted on 8/6/03 at 05:18 PM |
R olling A round T he FL oor My Aching .... what does th 'O' stand for?
Metal Hippy
posted on 8/6/03 at 05:33 PM |
Rolling Around The Floor Laughing My Arse Off
Cock off or cock on. You choose.
Alan B
posted on 8/6/03 at 06:09 PM |
Rolling ON the floor......actually
Although in fact I wan't really.......spoiled it now...
Still funny....
Metal Hippy
posted on 8/6/03 at 06:11 PM |
I dunno why I typed Around.
Hell of a typo that, spelled out a whole different word...
Alan B
posted on 8/6/03 at 06:25 PM |
Common mistake....easily done....
Don't feel too bad....
8smokingbarrels
posted on 9/6/03 at 02:00 PM |
Since we're on the subject of abbreviations:
What does IMO mean? Alan uses it a lot
Im Most Outlandish perhaps?
timf
posted on 9/6/03 at 02:57 PM |
In My Opinion
or
IMHO
in my honest opinion
posted on 9/6/03 at 04:28 PM |
I thought that IMHO was "In My Humble Opinion" IMHO
craig1410
posted on 9/6/03 at 07:15 PM |
Yeah, I thought it was "Humble" too. Just shows you how you could get into trouble with a misunderstanding.
eg. Your car is crap IMHO could have an important difference depending on whether it is "Humble" or "Honest" although I guess
you'll get a smack in the mouth either way...
Craig.
Dick Axtell
posted on 9/6/03 at 08:11 PM |
Craponyms
Since we've now veered on to these, can anybody explain "IIRC"?
Metal Hippy
posted on 9/6/03 at 08:12 PM |
If I Remember Correctly?
posted on 9/6/03 at 08:36 PM |
Take a look at http://www.geocities.com/CollegePark/Campus/4642/irchat.html for most of the common ones. There is at least one incorrect on there
though, we all know that FUBAR does not stand for "Fed Up Beyond All Recognition". The last four words are correct though.
My favorite is SNAFU
mranlet
posted on 13/6/03 at 07:22 PM |
Sounds like the US Military in here...
