bitsilly
| posted on 30/11/06 at 02:28 PM |
R1 MNR Weight?
Has anyone ever weighed an MNR with R1 engine, I'm trying to figure out how much the orange ex-demo car we've bought weighs to see the
power to weight ratio.
The orange body is heavier than the new one as it's thicker, and it now has a full cage. Also according to a recent article the chassis has
since been changed a bit. Any ideas?
bitsilly
| posted on 30/11/06 at 02:45 PM |
Read somewhere it weighed 440kg before the cage, add say 25 for the cage. I think it's a standard R1 which is dyno'd and rolling roaded.
That I guess means 150 bhp ?? Anyone know better?
TimC
| posted on 30/11/06 at 02:47 PM |
I reckon you're about right.
smart51
| posted on 30/11/06 at 02:56 PM |
an early RT+ without the full cage, with the lightweight bodywork, with a fireblade engine was weighed in 397kg.
My RT (sierra uprights and vented discs) with standard bodywork, padded seats, boot box, R1 engine, LSD and heavy bolt on shaft and a big bag FULL of
tools weighed 540kg wet. I wish I'd remembered to remove the tools to get a proper weight.
I'd have thought an RT+ without a full cage or boot box would be just under 500kg.
[Edited on 30-11-2006 by smart51]
chockymonster
| posted on 30/11/06 at 03:18 PM |
I'll let you know soon!
G.Man
| posted on 30/11/06 at 03:45 PM |
My RT+ with zx12r and very heavy cossie diff/shafts is 540kg wet...
I would imagine an R1 engined version with open diff will come in around 490kg..
Opinions are like backsides..
zxrlocost
| posted on 30/11/06 at 04:00 PM |
your looking at about 330bhp per ton
Agriv8
| posted on 30/11/06 at 04:06 PM |
Lighter than a V8 one     .
Regards
Agriv8
smart51
| posted on 30/11/06 at 04:07 PM |
What does your V8 car weigh?
TimC
| posted on 30/11/06 at 04:23 PM |
I'm a fraction disappointed!
I was hoping to be much lighter than this!
My old CBR1000 MK with Cobra Roadster7s, Carpet, Stainless Tank, 17s etc etc weighed 565kgs!
{Edit to remove huuuuge overstatement}
[Edited on 30/11/06 by TimC]
Agriv8
| posted on 30/11/06 at 04:24 PM |
more than a R1 one   .
About 650 - 700 wet ( I belive will get it on the scales when I next swap the front spring )
regards
Agriv8
| posted on 30/11/06 at 05:11 PM |
Not an MNR but our virtually standard ZX12R MK Indy weighs in at less than 500kg (weighbridge +-10Kg). It also has Sierra Hubs/Diff bootbox, diffuser
etc.
500kg+ for a R1 sounds a bit too much.
zxrlocost
| posted on 30/11/06 at 05:47 PM |
TimC what are you dissapointed about 100kg difference is huge
itll make an r1 motor stinkingly quicker responsive etc
go and take a load of stuff of you tin top car to save weight fill a box full of interior poo and youd be lucky to put 6kg in there not including
seats
were talking about cars that are already fully stripped and then saving another 30 40 50kg
bitsilly
| posted on 30/11/06 at 06:50 PM |
Tim
the orange one has heavier body work and has a quaife reverse box too, should be good for a few kilos.
TimC
| posted on 30/11/06 at 07:31 PM |
Ok, I've edited my initial post as I've hugely ovestated my feelings.
In my mind, I always wanted to get to 440kgs (and 155bhp) to give 350bhp/tonne. I don't necessarily expect this 'out of the box' as
I'm not going for Wilwoods and ali hubs and the driver's seat I've ordered has a little foam and vinyl on top of the fibreglass
shell. All (perhaps except the seat) I plan to upgrade later.
However, on reflection I don't think I'll be far off with lightweight bodywork, 13s, a tiny fuel tank and stripped loom.
I just don't fancy being overtaken by a Sprint-R (that means you Mr Mason )or pesky Striker!
G.Man
| posted on 30/11/06 at 08:59 PM |
spend the money on a vortx super with t45 chassis..
chockymonster
| posted on 30/11/06 at 10:18 PM |
Or an RT+ with a T45 chassis, I did think about it at order time, but seeing as I originally wanted an RT I figured I'd leave it as it was
road warrior
| posted on 30/11/06 at 11:20 PM |
Our RT+ with full cage, lightweight bodywork, muffet diff, Raceleda front end, '05 R1, 13" compomotives and two seats weighs in at 460kg.
The '05 R1 weighs 70kg dry with all electrics and ECU.
Seats have Sparco runners (at 2kg a set plus mountings). You can save some track day weight by leaving out interior panels and only having one seat.
Your car probably weighs about the same as the cage/bodywork difference is probably similar.
marc n
| posted on 1/12/06 at 06:52 AM |
orange car now weighs 505kg with full cage, and full of fuel (approx 40 litres) and with the 15s tsw wheels, as mentioned the orange bodywork is
heaveir than normal due to colour had to be thick so the colour didnt look see through
whilst redoing the website im doing a small database like fluke had giving weights for each component so you can calculate how / where to save weight,
trimming all bolts to correct length and using cap heads saves from memory 7kg on a whole car, wheels are a big area to save weight, as are seats,
comfy ones we use are 7kg heavier each than a fibre glass version, got to weigh my racecar again today if i have chance so will update what it is now
its finished
best regards
marc
please email rather than u2u
chrismnrltd@btinternet.com
procomp
| posted on 1/12/06 at 08:33 AM |
Hi so 40L of fuel is 28kg and the full cage is an extra 14kg =42kg so car 505kg - 42kg = 463 kg with no fuel.
Less 10kg for extra bits and heavey paint you have a total'ish of 453kg plus fuel.
cheers matt
TimC
| posted on 1/12/06 at 08:34 AM |
Trust me, it's been talked about.
marc n
| posted on 1/12/06 at 09:49 AM |
yep minus difference for 13 inch cxrs as opposed to 15 inch tsws ( another 10kg ??? ) plus old style chassis bit heavier
just weighed my racecar 425kg with full fuel approx 40 litres fully road legal with lights two seat s etc
car spec
fireblade engine
t45 chassis and wishbones
hex bolts etc
quaiffe reverse box
siuerra diff and shafts
stainlessw silencer
still some potential for some weight saving, mainly diff and shaft swop for free lander and a better alternative for a quiaffe box as they must weigh
a good 10 kg all day long,
my new ally silencer i have to fit saves 3.5kg over the stainless one which isnt taken into account in the weights above
freelander diff is quite a bit lighter than sierra cant remember how much
so if you can find a lighter way of getting reverse, ally can and freelander diff some lighter front lights the ones we use are about 2kg each you
could get another 25kg - 30 kg off possibly more with caphead bolts etc
so very possible to end up just under 400 kg with a full tank of fuel
im keeping the sierra diff on mine and the quaiffe as otherwise will have to add more lead already have to add 60 kgs for min weight in rgb
TimC
| posted on 1/12/06 at 09:57 AM |
Marc
Any idea what the weight saving from the T45 is?
TC
bitsilly
| posted on 1/12/06 at 11:13 AM |
Cheers for that Marc, very helpful!
Do you know what the output is, says somewhere that you had it rolling road tuned??
Just on a minor point for builders planning an SVA, the inspectors need to see two full threads past important fixing bolts, so don't trim too
tight initially.
bitsilly
| posted on 1/12/06 at 11:22 AM |
and never underestimate the power of good laxitives, cheapest way by far of upping power to weight.
