New Topic New Reply
Author: Subject: How to widen a rollbar?
scutter
posted on 8/12/06 at 07:18 PM Reply With Quote
I recently brought a rollbar off Ebay and it's too narrow( I know I should have checked first)
Any ideas on how to straighten out the bends? It's 1 3/4" * 3mm CDS.
ATB Dan.
[Edited on 8/12/06 by scutter]
Surrey Dave
posted on 8/12/06 at 07:20 PM Reply With Quote
Lots of heat I would have thought.
stevec
posted on 8/12/06 at 07:23 PM Reply With Quote
I think on such an important bit of the car it would be a bad idea to try and alter the bends.
What about having a piece profesionaly fitted to the middle.
Steve.
Wadders
posted on 8/12/06 at 07:27 PM Reply With Quote
warm it up to a nice even cherry red, all of the bend and an inch or so either side, then just tweak as required, you'll need access to a set of bottles though.
ATB Dan.
snapper
posted on 8/12/06 at 07:30 PM Reply With Quote
My solution would be to cut it in half, insert tube of diameter to go snugly inside one half, tube of original diameter over that and butt to original tube( this fillet is cut to the increased width required) and welded, then other original side slipped over the inner tube and welded again. It won't cost a lot, it will take some time and effort, it will be at least as strong as the original, probably more. As it is a roll bar you want it to be strong.
I eat to survive
I drink to forget
mark chandler
posted on 8/12/06 at 07:43 PM Reply With Quote
I made mine from an old bed headboard, to gain width I cut a slice out of each curve and welded up.
This is not any good for MSA as the tube has to be a single piece, not that you get any where near MSA spec with a scabby old headboard !
Regards Mark
[Edited on 8/12/06 by mark chandler]
posted on 8/12/06 at 08:48 PM Reply With Quote
a headboard?! i thought mine was bad
Wadders
posted on 8/12/06 at 08:50 PM Reply With Quote
Crikey Mark, thats like using an old bread bag for a condom !!
mark chandler
posted on 8/12/06 at 09:23 PM Reply With Quote
I like to get years of work out of my beds !
well if thats all that fits...
Stu16v
posted on 9/12/06 at 12:34 AM Reply With Quote
Whats wrong with that?
zetec7
posted on 9/12/06 at 03:06 AM Reply With Quote
Drat...I thought everybody did that! I find that a snug-fitting rubber band helps, tho....
http://www.freewebs.com/zetec7/
gazza285
posted on 10/12/06 at 10:11 PM Reply With Quote
I've managed to straighten out formed bends a little by using brute force, just put one end under something solid and push. For the little amounts you need you should be ok.
Syd Bridge
posted on 11/12/06 at 08:58 AM Reply With Quote
Only one safe way to widen a rollover bar................replace it with an item of the correct dimensions to start with!
How much is your life worth?
Syd.
NS Dev
posted on 11/12/06 at 09:09 AM Reply With Quote
my thoughts exactly...........wasn't sure whether some of the answers were jokes or not, presume the bed one was having a laugh!!!
Make a new bar and sell the old one
scutter
posted on 11/12/06 at 09:40 AM Reply With Quote
I totally agree, the thought has been sat at the back of my mind all weekend.
Thanks to all, Mark you don't need a CDS replacement bedhead do you
ATB Dan.
posted on 11/12/06 at 10:45 AM Reply With Quote
Has anyone actually ever rolled a locost? I've spun mine and done various other stupid stunts but never actually come close to getting more than one wheel off the deck. I fitted one as a handy handle to push with.
iank
posted on 11/12/06 at 11:01 AM Reply With Quote
http://www.youtube.com/watch?v=svzmp56YPY0
posted on 11/12/06 at 11:05 AM Reply With Quote
One of my son's friends rolled his Caterham... and walked away with only minor bruises due to the full cage.
I was also impressed that Caterham fixed the car afterwards, for not too much money.
Jon Ison
posted on 11/12/06 at 11:09 AM Reply With Quote
yup, me too
Take the advice above, source and fit a proper sized replacement.
[Edited on 11/12/06 by Jon Ison] Rescued attachment smash.JPG
posted on 11/12/06 at 01:03 PM Reply With Quote
Yes but they aren't Locosts
They are obviously not as good as the real thing I like the way the barrel roll landed back on its wheels.
iank
posted on 11/12/06 at 01:16 PM Reply With Quote
I like the way he apparently only broke an arm after a cartwheel like that. I expect he probably needed to put his race overalls in for a dry clean as well
Good advert for a full cage and the strength of a bronze welded chassis.
procomp
posted on 11/12/06 at 03:04 PM Reply With Quote
Hi and people still worry about the extra 14kg of weight high up on thier chassis whith a full cage. You may think it will never happen to you but you never know whats round the bend.
cheers matt
New Topic New Reply
