posted on 29/12/06 at 07:01 PM |
Desperately Seeking I.T. Help
After recent scares about Windows XP security issues I have been installing all of the latest Upgrades.
I have Windows XP Pro SP1 and the updates were quite extensive to say the least.
After the Upgrades I got the messages to REBOOT, which I did. Now the bloody thing won't start up properly!
It boots up in SAFE mode only, it will not boot up SAFE with NETWORKING enabled. Therefore I am suspecting it is a Networking issue...
When in SAFE MODE I cannot uninstall any of the Network applications. Therefore I am in a position of seeking help with this one. Although I am not
adverse to ripping it apart and making registry things I suspect I may have to access things in a different way now, this is the first time anythiung
like this has happened to my system. I need the Networking side as I am currently using a WEP Network at home.
Any help to resolve this issue would be really appreciated as I am now resorting to the Laptop for a while.
I am going to try to start/repair from the CD for now until I learn of anything better to do from any of you guys...
TIA - Steve
[Edited on 29-12-06 by Hellfire]
Alfa145
posted on 29/12/06 at 07:07 PM |
When booted in safe mode open Add/Remove programs and tick the "Show Update" option at the top.
Scroll through and see if you can find any networking update that you may have applied and see if you can remove it
Catpuss
posted on 29/12/06 at 07:11 PM |
You should be able to remove each update one at a time from add/remove programs (control pannel)
Tick the show updated option and remove them one at a time based on install date (i.e. latest first).
If you have a check point set then you could roll back to prior to the update.
You could also try removing the hardware via control pannel system in safe mode.
This way it will try to find new drivers. Useful if its a driver that has knackered the set up. In safe mode its a little more thorough sometimes when
removing a driver.
The other option is to open up the PC and remove any network cards (assuming your network ports are on cards not mother board), or disable them via
the BIOS (if they are motherboard based).
RichardK
posted on 29/12/06 at 07:51 PM |
As said before, safe mode and go into control panel and check the box at the top which shows updates and the time and date, remove them one by one to
find to culprit or if you can't be arsed doing that use system restore to go back in time, "Start, Programs, Accesories, System Tools,
System Restore.
Would only try doing the install cd thing really as a last resort.
Regards
Rich
Gallery updated 11/01/2011
posted on 29/12/06 at 10:29 PM |
OK... it's like this.
I'm still no further forward. My version of Control Panel does not have the top tab showing updates (?)
I've also tried doing a System Restore for a yesterday, never worked. Day before, never worked. I'm up to 5 days ago and having little
luck - the message it is saying is simply that it cannot restore to this date and to try a different date.
I have tried to remove the latest Microsh!t Network 1.1 and 2.0 updates shown in my Control Panel. However, it says I cannot remove in Safe Mode...
great!!!
It is currently restoring back to 1 week ago but I don't hold much hope. My XP CD is out and ready to try a repair using this... maybe it is
time I backed up everything on my second drive?
I haven't tried a network disable yet... I'll try that before I do! Don't you just love Microsh!t software....
Incedentally - on boot up it goes through normal procedure with the Windows Pro moving blue blocks then a very brief BLUE SCREEN OF DOOM flashs up
before resetting... could it be a virus?
ecosse
posted on 29/12/06 at 11:10 PM |
Try a logged boot, should be available from the boot menu, it will write a file to the root of the drive.
Check this file after booting with logging set and see what the last driver loaded is, chances are this will be what is causing the problem.
Although it does sound a bit like the network card driver is the cause, you could try disabling it in devices and reboot.
Alex
posted on 30/12/06 at 12:09 AM |
Have not got a network card... the only thing I have changed is update XP!
Right, I am writing on my newly re-written XP OS and everything is ok. There were a few illegitimate .dll's on intial startup and I'm
working to find what they were for.
However, when XP updates I think it must update antivirus files and as such conflicted with my AVG installation. I'm assuming this due to my
anti-virus software crashing upon successive boots... after re-installing my AVS everything is tickety-boo. My Network is working correctly with no
alterations etc... thanks for the advice chaps. Your help although not helpful in the slightest I have learned a little bit more about this
confounded machine. TBH I love messing about with trivial things anyway - thats how I ended up builinding my own car...
Many thanks - Steve
posted on 30/12/06 at 10:22 AM |
New developments I'm afraid...
After re-installing my New XP Original without my Anitivirus Software updating again... it's bombed out on me again!
What is it with these updates???? I'm considering not bothering at all... it's causing me so much hassle.
Right, so I re-installed XP back to basics again.... when it boots up it gives me errors to do with some .dll's these are some of them:
msdaosp.dll
msdaora.dll
msdaaps.dll
I know its a Microsh!t Data Access file but what does it do?
Your help would be appreciated pleeaase... Steve
ecosse
posted on 30/12/06 at 10:56 AM |
While the update process will occasionally cause problems its rare to see it cause what you are describing!
And unfortunately XP without the updates applied would not be something I would like to use.
The dll's you have listed are used by any program requiring ODBC connectivity, and are installed by default, possibly the updated (service pack
version) is not compatible with a program you have installed, or is possibly corrupted?
Its hard to say without more info
What are the exact errors relating to the dll's?
Alex
PS
I should have said network device maybe, as you obvously connect via something ![](/images//smilies/shocked.gif)
