ayoungman
posted on 28/1/07 at 01:58 PM |
steering rack width ?
Can someone please tell me the width of their steering rack that is fitted with extensions. I'm after the total length, end to end, before Track
rod ends are fitted ?
i've got a standard escort rack---too short. 102cm
fitted extensions-------too long !
so I'm having to modify, so if someone could give me a ball park measurement, I can crack on
Cheers fellas !
[Edited on 28/1/07 by ayoungman]
"just like that !"
ayoungman
posted on 28/1/07 at 09:12 PM |
Come on guys, I need the approximate length so that I can recut the thread and welde the extensions on in the right place. I don't have wheels
yet so can't easily adjust toe in etc.
"just like that !"
soggy 3
posted on 29/1/07 at 12:23 AM |
Hi mate for starters dont weld on the extentions its a sva no no i belive i have a better solution, i had the same problem a while back and my dad
said when he did rallycross back in the day he used to buy longer trackrods lots of searching turned up nothing but at a classic show we were pointed
in the direction of a guy in the buisiness and he said he can get some made, three months later and a result longer track rods (about 15mm longer)
I will take some pics tomorrow and find his number he had a few pairs made up and the good bit is they only cost £40 a pair!
Rudy
posted on 29/1/07 at 07:23 AM |
Sorry I can not help you becouse I used sierra uprights.
Sorry about my English
DaveFJ
posted on 29/1/07 at 10:05 AM |
How about cutting the track rods a little shorter and re-cutting the threads?
you could then use your screw on track rod extensions
(I have exactly the same problem so am inerested to see how you get on....)
Dave
andrew.carwithen
posted on 29/1/07 at 04:24 PM |
That's exactly what I did.
I'm using a standard width escort rack and cortina uprights.
Obviously, wasn't wide enough (excess toe-in) and so ordered extensions from Tiger. When fitted, the opposite happened - i.e too wide and excess
toe-out!
So, I cut about 15 - 20mm off each track-rod and re-cut the thread. Use a die and stock to do this - a dienut will not cut a clean thread!
Andy.
DaveFJ
posted on 29/1/07 at 04:41 PM |
What's the thread on the extension arms again?
Dave
ayoungman
posted on 29/1/07 at 05:36 PM |
well fellas, I've had a root around the garage and just happen to have found just the tool !
Its M14 metric course thread.
"just like that !"
ayoungman
posted on 29/1/07 at 05:38 PM |
Wooooow, thats Huuuuge !!!
"just like that !"
Ian Barraclough
posted on 29/1/07 at 11:10 PM |
steering rack
I am trying to remember what I did! ah ! thats it
I fitted only 1 spacer at one end then adjusted to suit .you end up with slightly more lock one side than the other but you dont notice and it works
fine. !
BB
