Author: Subject: Helmets test
jack trolley
posted on 1/2/07 at 07:17 PM Reply With Quote
Helmets test
RIDE magazine did a thorough test of helmets including a "spike in the helmet" test.
www.ridetriangles.com/pdf/643/221609.pdf (6 Mb)
Coose
posted on 1/2/07 at 10:45 PM Reply With Quote
That's fine if you have a Shoei shaped head. Mine's Arai shaped.....
(not that I'm complaining! )
Spin 'er off Well...
Simon
posted on 2/2/07 at 12:01 AM Reply With Quote
I've an Arai, used to have a Shoei, both good helmets.
Standard test is as they would be expected to perform in a typical m/c accident ie vertical drop about 5 feet.
That's all.
The Arai's have a much much stiffer area in the region below ears whereas most others can be squshed together.
Simon
