bracey
posted on 4/2/07 at 03:20 PM |
greengauges speed sensor
anyone know which way up magnets should go when fitting this sensor with a telematrix speedo?ie dimple up dimple down
?cheers
bracey![](/images//smilies/sad.gif)
posted on 4/2/07 at 06:49 PM |
Can't help with the magnets but I used the propshaft securing bolts instead with mine . Was OK for SVA and no problems in 2 years. PS If you are
using their fuel gauge and sender test the operation of the sender before actually cutting the arm to length, on mine tha gauge was reading in reverse
even though I fitted it exactly according to the instructions . Ended up fitting sender upside down to resolve the problem . Believe others have had
this as well
ady8077
posted on 4/2/07 at 11:07 PM |
Is this for the reed switch? if so i dont think it maters, i've just fitted some new ones to my wheel rims and they didn't have any
dimples, speedo still works ok
Ps i originally fitted them to the propshaft, but this made the speedo jump about over 60 mph
Adrian
posted on 5/2/07 at 07:45 PM |
Trick when using the prop bolts is to align all the heads , Mines OK well over the legal limit
bracey
posted on 6/2/07 at 05:24 PM |
im fitting the magnets in the prop and just need to know which way up to put the dimple ,someone must know and cant find any answers on net and green
gauges are not returning my calls heeeeeelp please ![](/images//smilies/tongue.gif)
bracey
posted on 11/2/07 at 05:34 PM |
having messed about with magnets found they stick either way up??? so logic would assume dont matter which way up i fit them!!! anyway they are now
in dimple up and we will see once speedo wired cheers anyway
richard
bracey
posted on 13/2/07 at 06:22 PM |
had reply from mary at europa spares ,she says dont matter as long as all dimples are the same phew glad cleared that up
