Author: Subject: wanted - valve springs for SVA steering mod
posted on 14/2/07 at 09:12 AM Reply With Quote
Has anyone got a couple of old valve springs they could donate for an SVA steering mod?
I'd be happy to send a self addressed envelope with postage.
Nick
posted on 14/2/07 at 10:15 AM Reply With Quote
Whats the mod? Is it in responce to a SVA fail?
Would be nice to know in case we all have to do it!
posted on 14/2/07 at 10:23 AM Reply With Quote
Hi Steve,
Not in response to a fail, but several people have advised on fitting a valve spring to each side of the steering rack shaft, between the tie rod and rack body. The purpose is to add some self centering assistance and to limit the full lock of the rack by a small amount.
I have my SVA in 2 weeks - I may go without the springs and only fit them if it comes up as a failure.
Others may be able to offer more advise on this?
Nick
chockymonster
posted on 14/2/07 at 10:28 AM Reply With Quote
Steve,
You won't have any issues with this. The Vortx has a decent amount of castor.
James
posted on 14/2/07 at 10:39 AM Reply With Quote
I've found that with use of the car, the self centring has improved greatly. I suspect it's that the balljoints have freed up somewhat from their initial (out of the packet) stiffness.
James
zxrlocost
posted on 14/2/07 at 10:45 AM Reply With Quote
you need to drive your car first somewhere nick and see what happens
theres not much chance of it self centering
ta chris
posted on 14/2/07 at 10:58 AM Reply With Quote
ta chris
I've driven at low speeds, but not really been able to get a feel for it. The first "proper" drive I'll get will be en route to the SVA
zxrlocost
posted on 14/2/07 at 11:09 AM Reply With Quote
full lock at low speed, steering wheel should want to move back towards the middle
search for my self centering thread HOW TO
mad4x4
posted on 14/2/07 at 12:39 PM Reply With Quote
LOTS of toe out should help but put it on just before going into the test as if you have a long drive you'll strip the tyres
Plus it may dangerous to drive
Scot's do it better in Kilts.
posted on 14/2/07 at 12:41 PM Reply With Quote
Right - plan is to SVA using toe and tyre pressure settings and hold the valve spring idea in reserve.
Thanks for the advice guys!
Nick
Paul G
posted on 14/2/07 at 02:03 PM Reply With Quote
if all else fails and you use the valve springs DO NOT let the sva tester know about it!
RazMan
posted on 14/2/07 at 02:45 PM Reply With Quote
Wouldn't this be just the same as putting in a shim to limit the lock? (eg. if you have a clearance issue) A 'springy shim' would just give some tactile feedback before full lock is reached.
Raz
Paul G
posted on 14/2/07 at 04:29 PM Reply With Quote
Dont know but my SVA tester specifically asked if I had put springs in as that would be a fail (I had done cos I've got an Indy but of course I just lied and said no - they arent allowed to peel off the rack boots to have a look!)
posted on 14/2/07 at 04:38 PM Reply With Quote
You sure? I was under the impression they could ask you to remove anything "removable" to check things out.... Peeling back a gaitor sounds very do-able... Depends how nice / mean the examiner is going to be- mine just said "oh- you should really make sure it self-centers cos otherwise it's dangerous but it seems a shame to drag you back here to re-test it.... as long as you promise to do it when you get back to the garage...."... LOL
Stu16v
posted on 14/2/07 at 08:46 PM Reply With Quote
If the car is being assessed properly, the valve spring theory wont make a blind bit of difference...
