Author: Subject: Mighty Engine "MYT"
Alez
posted on 18/2/07 at 12:17 PM Reply With Quote
Mighty Engine "MYT"
Unprecedented power to weight and power to volume ratio:
http://www.youtube.com/watch?v=zqSIq39TMNM
http://www.youtube.com/watch?v=kGlUZg2pC0Q
http://www.angellabsllc.com/index.html
Sorry if it has been discussed previously, the LB search engine found nothing.
Alex
[Edited on 18/2/07 by Alez]
SeaBass
posted on 18/2/07 at 01:23 PM Reply With Quote
It seems a very interesting concept - but as yet no evidence it run on fuel and no patent??
How could such a small output shaft handle 813ft/lbs of torque too??
I just cant help being wary of claims like these.
posted on 18/2/07 at 01:31 PM Reply With Quote
the problems i see are the tips of the rotors wearing, just like a rotary engine, and also they dont explain what makes the two rotor sets move differently, i belive that starting and stopping them could waste a lot of power/effort. Would be nice to see a working model though!
in that second video, he says it produces 800lbft of torque at 800rpm. If you bear the gearing in mind, thats not that good...
[Edited on 18/2/07 by JoelP]
Confused but excited.
posted on 18/2/07 at 05:58 PM Reply With Quote
I would like to see one running on fuel for an extended period. He claims to have run one on biofuel but there is no video of the run. It is a very elegant design and 'theoretically' feasible. I am concerned that he states that the only friction losses are in the 'piston' rings. The close tolerences required to prevent gases escaping between the rotors that the pistons are mounted on would produce some drag due to lubricant viscosity surely.
I am not convinced but him just pushing it around with compressed air.
Very impressive concept though.
DIY Si
posted on 18/2/07 at 06:21 PM Reply With Quote
Comp raio of 20:1 with American pump gas? Surely that'll just blow up!
Sun Tzu, The Art of War
Middy Tim
posted on 18/2/07 at 06:37 PM Reply With Quote
American pump gas? Surely you mean cat urine.
DIY Si
posted on 18/2/07 at 06:39 PM Reply With Quote
Yup, that's pretty much what I meant!
American beer and fuel, both are pretty close to water!
flak monkey
posted on 18/2/07 at 06:40 PM Reply With Quote
Seen the design somewhere before, probably mentioned on here. The claims are certainly very high, would be interesting to see an independant test.
[Edited on 18/2/07 by flak monkey]
Sera
http://www.motosera.com
Alez
posted on 19/2/07 at 08:41 AM Reply With Quote
Put it this way, if it does a tenth of what's claimed, that's still absolutely awesome..
NS Dev
posted on 19/2/07 at 09:42 AM Reply With Quote
Not read about it yet, but in answer to that statement, no, it probably wont.
Decent engine designs can tolerate huge compression ratios without detonation.
Have a look at some of the rotary valve designs around, these can burn very low octane fuels at high compressions with no issues at all.
