Author: Subject: V6 input shaft shorening
ibakes
posted on 23/2/07 at 01:38 PM Reply With Quote
Hello
What the best way to shorten the input shaft of a V6 type 9 gearbox.
And whats this about 19 or18 teeth, im sure when i put the clutch over the shaft it fitted ok? or am i barking up the wrong tree?
[Edited on 23/2/07 by ibakes]
GeoffT
posted on 23/2/07 at 02:04 PM Reply With Quote
Mine was about 10mm too long - I used nothing more scientific than the angle grinder with a thin cutting disc. Make sure you leave a chamfer on the cut edge to give it a lead into the spigot bush though.
ibakes
posted on 23/2/07 at 02:11 PM Reply With Quote
Thats what I was thinking, just want to make sure.
also heard of the teeth catching on the flywheel
macnab
posted on 23/2/07 at 02:18 PM Reply With Quote
hmm I had a major problem years ago with this, didn't know there was a difference and wrecked the grearbox
bilbo
posted on 23/2/07 at 02:34 PM Reply With Quote
Before you do this though, IIRC the longer shaft boxes are very sort after. It may be worth selling it and replacing it with a shorter shaft one, and make a bit of money at the same time.
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
ibakes
posted on 23/2/07 at 02:44 PM Reply With Quote
so better option will be change it for the shorter one?
must check the teeth on the clutch again when I get home
paulf
posted on 23/2/07 at 03:42 PM Reply With Quote
Thats because they are slightly stronger and have a better first gear ratio.
I would make it fit somehow, either by shortening the shaft or by making or buying a spacer to fit between the gearbox and bellhousing i think caterham use them.
Paul.
ibakes
posted on 23/2/07 at 04:05 PM Reply With Quote
the caterham one is 38mm, I measured 30mm last night.
Not sure how much the caterham one is but BGH do a stronger shorter shaft for £80+vat, think I may have a go with a hacksaw and file later on, unless anyone can let me know of a good reason why not
paulf
posted on 23/2/07 at 04:26 PM Reply With Quote
I think that you will find that cutting that much off the shaft will mean having to cut it off to the splines therfore leaving no spigot for the bearing.You may be able to get the end of the splines turned down though as long as it leaves enough for the clutch plate to fit onto.
Can you find a bit of 30mm alloy and cut a spacer from that?
Paul.
ibakes
posted on 23/2/07 at 04:43 PM Reply With Quote
im pretty sure there is 50mm between the end and the splines...
mookaloid
posted on 23/2/07 at 05:06 PM Reply With Quote
After looking long and hard at my long shaft box, I fitted the caterham spacer. I did this because I wasn't happy that the splines would be short enough to clear the flywheel and spigot bearing.
The caterham spacer is a quality item and makes it all very easy IIRC it was about £50 but a quick call to their parts dept would tell you exactly.
It would be a shame to ruin a good long shaft box - don't do it!!!!
Mark
[Edited on 23/2/07 by mookaloid]
