Author: Subject: 1/2 way there.....Viento Sized Car Ramps
wilkingj
posted on 25/2/07 at 07:27 PM Reply With Quote
Well Its been another busy weekend in the garage. I've almost finished one of my car ramps that I am building. Just a couple of cross braces to do, and finalising the welding, as some is still just Tack Welded.
Its meant to be built upside down!. The car is driven up the ramp until the car is completely on the ramp. Then lift the rear up with a Jack to give a level platform to work from. There will be a couple of bars to link and steady the two ramps.
I will also make a moveable jacking beam so I can lift the car clear of the ramps so I can work on the suspension etc.
Its coming along but a bit slower that I had planned.
The Sloping part is 2.4 metres long, the square part 1.2 metres long and 420mm wide. Each ramp breaks down into two parts, for easier storage and transport.
Its certainly got to be better than grovelling about on the floor to work on the Viento.
1st One Nearly completed
Best Regards
Geoff
http://www.v8viento.co.uk
macnab
posted on 25/2/07 at 07:35 PM Reply With Quote
sorry had to laugh when I saw that!
comedy ramps like that giant mobile phone that guy used on the bus...
some diagonals might be needed here.
blue2cv
posted on 25/2/07 at 07:51 PM Reply With Quote
Theres some for sale on Ebay at present
macnab
posted on 25/2/07 at 08:08 PM Reply With Quote
after all that work I don't think I would have mentioned that
Confused but excited.
posted on 25/2/07 at 10:36 PM Reply With Quote
Evil Knievel lives!
wilkingj
posted on 25/2/07 at 11:09 PM Reply With Quote
Got the link, I cant find them?.
Best Regards
Geoff
RazMan
posted on 25/2/07 at 11:45 PM Reply With Quote
[crocodile dundee mode]
Now that's a RAMP
Raz
posted on 26/2/07 at 09:05 AM Reply With Quote
Hats off to you for ingenuity, but you're a braver man then me to drive up them
wilkingj
posted on 26/2/07 at 06:11 PM Reply With Quote
Not my ingenuity... Ive seen bigger ones at shows, much steeper and higher, with Land Rovers on them. Thats where I got the Idea. Also my local car dealer has something similar for displaying his cars.
Mine should be OK, for a 800Kg Viento.
You drive up them, and then jack the back end of the Ramps up. It then tilts level at about 600mm from the ground. There will be some support legs at the back to hold it in place.
There will be some more cross bracing, and the two ramps will be linked together with a couple of bits of scaffold pole pinned into a tube to make them act as one Ramp.
Its not finished yet!
Best Regards
Geoff
blue2cv
posted on 26/2/07 at 06:51 PM Reply With Quote
Ebay item number 28008538120, sorry mate did not mean to pee on your bonfire
posted on 26/2/07 at 06:53 PM Reply With Quote
How much time are you thinking of spending under the car
wilkingj
posted on 26/2/07 at 09:04 PM Reply With Quote
Well...Not too much time under the car.
However, I do plan to have all the suspension bushes out and adjust them as the crush tubes are a bit too short, causing a squeeking suspension / stiff.
I also have a set of bigger brakes to put on.
Its not the underneath time, although I do plan on changing the sump as I scrape a few of the local traffic calming humps.
The Idea is simply to be able to work at a sensible height on the axles. rather than kneeling on cold hard concrete.
I'm 54 and my knees are giving me trouble already.
Courtesy of being a Bat F'Stard
EDIT:
YEOWCH!!! (See the price!!)
Just got this Link sent to me...
Linky
I think mine are the Locost version of these Rolls Royce jobbies.
Re: Winch...
I already have a 1 ton chain winch so dont need it. However, I also have a V8 "winch" under the bonnet in the car
[Edited on 26/2/2007 by wilkingj]
Best Regards
Geoff
iank
posted on 26/2/07 at 09:53 PM Reply With Quote
ewenspence made some similar, but all the pictures have been removed from the threads about them making it somewhat surreal to read.
For example:
http://www.locostbuilders.co.uk/viewthread.php?tid=30049
Anonymous
