roadrunner
posted on 6/3/07 at 09:50 PM |
CEC TO BEC UPDATE
Nige brought round his engine hoist this evening, what a nice man he is , cheers nige, took exhaust off yesterday, removed megajolt and coil pack,
disconnected coolant hosses, and unbolted as much of the engine as possible ready for jacking up and lifting the engine out.
Stay tunned tommorow for this gripping episode.![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/tongue.gif)
posted on 6/3/07 at 10:20 PM |
Listen for your chassis giving a BIG sigh of relief
Phil
greggors84
posted on 6/3/07 at 11:22 PM |
Surprising you don't see any BEC to Pinto Update posts really!
Chris
The Magnificent 7!
tom windmill
posted on 7/3/07 at 12:20 AM |
run to MK on sat then Brad????
scotmac
posted on 7/3/07 at 09:28 AM |
Surprising you don't see any Duratec to BEC Posts really! ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/wink.gif)
zxrlocost
posted on 7/3/07 at 10:16 AM |
no they sell the whole car and buy a BEC instead ![](/images//smilies/bigsmile.gif)
roadrunner are you done yet![](/images//smilies/bigsmile.gif)
Paul TigerB6
posted on 7/3/07 at 10:41 AM |
If you do go Brad give me a shout and we may just be able to work something out involving you finishing a little sooner than expected and me getting
my exhaust headers off MK if the dimensions work for fitment into my Tiger.
Paul
roadrunner
posted on 7/3/07 at 09:26 PM |
I've only just taken the engine out, lots of work yet.![](/images//smilies/cool.gif)
Toady1
posted on 7/3/07 at 09:59 PM |
i bet you still beat me to it! lol!![](/images//smilies/bigsmile.gif)
posted on 7/3/07 at 10:07 PM |
i did a crossflow to bec swap in a month, from lifting the engine to thrashing round a track. Fancy beating that?! We could make it a challenge for
people as they get converted.
roadrunner
posted on 9/3/07 at 09:49 AM |
Hi all.
Took the gearbox out yesterday and the prop , i thought i would have to remove the diff ,because the prop flange would'nt pass through the
tunnel, but it just needed a bit jigging and it was out.
Just the clock's to remove now, oh ,and to get over a bad back.![](/images//smilies/sad.gif) ![](/images//smilies/smile.gif)
Toady1
posted on 10/3/07 at 12:39 PM |
guess im nowhere near that leader board then! lol!
roadrunner
posted on 10/3/07 at 10:11 PM |
Well my engine has gone now, hope your build goes well Fleck, just got to wait two weeks now before i get my bike engine.
welderman
posted on 15/3/07 at 03:04 PM |
What do you think the overall cost would be, trying to convert my mate from cec to bec.
Thank's, Joe
I don't stalk people
roadrunner
posted on 15/3/07 at 09:04 PM |
The engine has cost me £400, exhaust manifold £150, silencer £20 ebay, propshaft and bearing £20 scrappie,prop alterations MK £80, prop adapter £60,
bike clocks £30, fitting of engine £50, i think thats everything, but i will probably be wrong.
[Edited on 15/3/07 by roadrunner]
Toady1
posted on 15/3/07 at 09:08 PM |
exhaust manifold and dynojet kit! ![](/images//smilies/wink.gif)
roadrunner
posted on 15/3/07 at 09:16 PM |
OOOPPS , i meant exhaust ,not inlet, by the way, this dynojet kit ,what is it ,and what does it do.![](/images//smilies/shocked.gif)
posted on 15/3/07 at 09:37 PM |
dynojet sorts out your fueling. Due to a less restrictive exhaust and air filter it will probably be running lean, which can melt pistons.
I just drilled my main jets (zx9) to 1.65mm and that sorted it fine. A few quid for a drill bit. I could feel it hesitating at first, once drilled i
got a slow build up of soot, confirmation of richness, which is better than leanness.
You did well on the exhaust! cheap!
Paul TigerB6
posted on 15/3/07 at 09:46 PM |
You hopefully wont need the dynojet kit so hold off buying that for now. Worth checking the jets in there with a 1.65mm drill bit if thats what they
are supposed to be.
Paul
roadrunner
posted on 15/3/07 at 10:56 PM |
Cheers fellas
jacko
posted on 16/3/07 at 04:02 PM |
Hi What about sump mod,s is there any needed?
Brad how much to fit the engine
Graham![](/images//smilies/bigsmile.gif)
roadrunner
posted on 16/3/07 at 06:54 PM |
![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
roadrunner
posted on 25/3/07 at 08:41 PM |
Picked my engine up this weekend, what do you think,
![](/galpreviews/24032007030.jpg) ![zx9r engine](/gallery/24032007030.jpg) zx9r engine
Managed to lift into and out of my golf's boot , on ny own, i would'nt of done that with the pinto.![](/images//smilies/shocked.gif)
matt_gsxr
posted on 25/3/07 at 08:48 PM |
roadrunner,
you mentioned in a previous posting manifold cost of £150. Is this DIY, or do you have a secret source?
I need one for a build (not zx9) at some point, and the cost is a bit scary.
Matt
roadrunner
posted on 25/3/07 at 08:50 PM |
MK enginering, so i've been told, i could'nt weld for toffee.![](/images//smilies/tongue.gif)
