Author: Subject: alternator tensioner
Pdlewis
posted on 10/3/07 at 08:12 PM Reply With Quote
I have just had to swop to an alloy RS style alternator bracket to prevent the alternator hitting the manifold. Now the tensioner bracket (flat alloy bit with a long hole in it for want of a better description) doesnt reach the alternator. is there a replacement part i can use or do i need to fabricate something?
Paul
DRC INDY 7
posted on 10/3/07 at 08:27 PM Reply With Quote
You will need to make a longer one or if you can pull the alternator closer to the engine and use a small belt
Puddle Dodgers Club
auzziejim
posted on 10/3/07 at 09:18 PM Reply With Quote
i made on from a couple of rod ends and some bits of threaded bar, a little over kill but looks the part
MkIndy7
posted on 10/3/07 at 10:28 PM Reply With Quote
There is also a tapping behing the alternator that you can see on the block in that picture.
You can insert a bolt and a use a lock nut on to tension the alternator.
