mkblade
| posted on 13/3/07 at 10:36 PM |
lower steering column bush
can anyone advise me on the above,ive now got my paddle shift and steering wheel fitted now
but i seem to have a problem when turning the steering wheel the plastic inner bush comes out of the rubber grommet (inner steering column goes
through it )ive taked the colmun in and out so many times but never had this problem untill now.
there is a metal clip/washer i dont think that is as tight fit as it should be has anyone eles had this problem ??
thanks
simon
| posted on 13/3/07 at 10:41 PM |
A jubillee clip is your friend. Put it round the column just behind the washer thingy and tighten it up- stops the column coming out....
jollygreengiant
| posted on 13/3/07 at 10:43 PM |
Push bush in, push metal retainer plate down, fit worm drive clip tight above it and tighten clip around column. JD.
Damn to sllllllllllllowwwwwwwwwww.
[Edited on 13/3/07 by jollygreengiant]
DRC INDY 7
have you fitted the inner bush from the top
Puddle Dodgers Club
mkblade
| posted on 13/3/07 at 11:49 PM |
i fitted the rubber bush into the bracket on the bulkhead then inserted the outer part of the plastic bush slid the column through the two then slid
the inner part of the plastic bush back up the inner column to make a snug fit then slid up the retaining clip as some of you have suggested maybe a
jubilee clip is in order
jollygreengiant
| posted on 14/3/07 at 05:11 AM |
Did You fit the inner bush to the column BEFORE you fitted the column into/onto the car or did you fit the inner bush onto the column AFTER you fitted
the column onto the car. ?
I ask becuase you should always fit the bush to the column & then column to car and then slide the bush DOWN the column into the outer bush which
has a curve in its top face to match the curve on the inner bush. The metal clip is always difficult to get in the right place because it is
directional, ie is will slide down the column but should never slide up the column (It will have been a right b*st*rd to have got on & up the
column), if it is slideing up then it needs the jubilee clip behind it because it has been fitted the wrong way round OR it has been over stressed and
its directionality has failed.
