arse2000
posted on 22/3/07 at 03:16 PM |
electric speedo
i am fitting an ellectric speedo can any one tell me how to get it working for the mph to work correctly. do you need some sort of sencer,and where to
put it,or any ideas will do thanks
[Edited on 22/3/07 by arse2000]
posted on 22/3/07 at 03:31 PM |
It depends upon the speedo used.
Some use reed relay sensors which pick up a signal from magnets mounted on a rotating surface (e.g. propshaft), other speedos use a variable reluctant
sensor which picks a signal from being near a spinning bit of metal (some people use diff bolts, some people (like me) make up a trigger wheel
specifically.... The advantage of the magnet based system is the gap between the sensor and the magnet can be bigger than with a VR sensor which
typically can only handle a 0.5-1.5mm gap.
arse2000
posted on 22/3/07 at 03:33 PM |
many thanks
RazMan
posted on 22/3/07 at 05:27 PM |
Some gearboxes have built-in sensors (MT75 for example) so it is worth checking.
Raz
