New Topic New Reply
Author: Subject: R1 problem
boszi
posted on 30/3/07 at 06:17 PM Reply With Quote
R1 problem
I build an R1 engined MK indy and yesterday was the first engine start. Engine is funktion the 1.,2.,4. exhaust manifold is discoloration to purple and hot, but the 3. manifold is only lukewarm. I have ignition spark. What is the problem? Carburator or compression? Can anybody help me? Sorry for my bad english and thanks your answers.
Peter
ReMan
posted on 30/3/07 at 06:22 PM Reply With Quote
A good start would be checking the spark plug on number 3. Does it spark? Is it wet with fuel?
posted on 30/3/07 at 06:23 PM Reply With Quote
We had a similar problem with our blade engined Indy... it turned out to be the Spark Plug Lead no connecting properly. We (sorry - I) shortened the leads and did not make the contact correctly. Yours will be coil packs... try swapping a coil pack and see if this cures the problem even though it sparks it may not be enough - just to eliminate a possible fault.
boszi
posted on 30/3/07 at 06:50 PM Reply With Quote
I swapping the coil packs and the problem is selfsame. But the spark plug i think is dry.
R1 STRIKER
posted on 30/3/07 at 08:58 PM Reply With Quote
Had a similar problem with my R1 on 1st start up. There is a way to reset the ecu by disconecting both battery leads and holding them together for 10 secs I think, maybe someone else knows if this is correct sequence. This was from a friend in the RAC, it worked a treat on mine.
Ben.
Jon Ison
posted on 30/3/07 at 09:14 PM Reply With Quote
If its a carb model and the plug is dry then its got too be a carb problem.
Check the floats are not stuck in the up position thus not allowing any fuel in,
A gentle tap on the float bowl may work, bike carbs are notorious for been a pain if left for a while with fuel in them, the fuel pressure is so low on carb engines they gum up and stick easily if left with fuel in them for long periods........
Tip, always drain the fuel off when standing for long periods.
OX
posted on 30/3/07 at 09:21 PM Reply With Quote
what jon said .if that doesnt work try swapping one of the spark plugs around and see if it changes the problem to another pot. .if that fails then it could be a blocked pilot jet .unscrew the brass jet and clean with a piece of wire from a wire brush and try again.
[Edited on 30/3/07 by OX]
auzziejim
posted on 30/3/07 at 09:43 PM Reply With Quote
i had a similar problem with bike carbs on my pinto which turned out to be an air leak with the joiner from carb to manifold. basically creating an over lean mixture on that cylinder.
took a bit of head scratching to sort
boszi
posted on 31/3/07 at 06:08 AM Reply With Quote
OK thanks, today I not to bored
posted on 31/3/07 at 08:16 AM Reply With Quote
Cracking English - ROFL.... don't we all have days like that eh?
New Topic New Reply
