Author: Subject: I finally got lucky - New blueprinted RV8
Fred W B
posted on 17/4/07 at 11:36 AM Reply With Quote
After pretty much finally deciding that I will have to rebuild the old smoker P6 RV8 I have, a tiny local paper add turned this up.
Brand new block, built and blueprinted by a reputable local engine builder 10+ years ago for a stillborn racing car project. Never been started, still with assembly lube inside. Oversize valves, gas flowed heads, roller rockers, dry sump, even came with the dry sump pump bits. Unfortunately somebody has pinched the lifters and pushrods, but it did came at the right price.
An invoice with the engine shows the intake manifold cost 127 UKP from RPI in 1995!
Fred W B
nrv82
nrv82
mookaloid
posted on 17/4/07 at 11:39 AM Reply With Quote
mmmmm nice
ned
posted on 17/4/07 at 11:46 AM Reply With Quote
has the inlet been matched to the heads?
very nice find
beware, I've got yellow skin
Fred W B
posted on 17/4/07 at 11:55 AM Reply With Quote
Everything has beem ported, blended, matched......
nrv85
nrv85
nrv87
nrv87
nrv86
nrv86
[Edited on 17/4/07 by Fred W B]
minordelay
posted on 17/4/07 at 12:03 PM Reply With Quote
Lovely, those Huffaker manifolds and rockers are worth a mint on there own.
Fred W B
posted on 17/4/07 at 12:05 PM Reply With Quote
nrv81
nrv81
nrv83
nrv83
nrv84
nrv84
Paul (Notts)
posted on 17/4/07 at 03:44 PM Reply With Quote
Engine looks fantastic and well prepared..
I would just be carefull of that paint on the timing cover.. I could be wrong but it looks like some paint has been allowed to go inside the dizzy hole. If it flakes over time it could end up blocking oil feed holes...
Just a thought looking at the pics.
Paul.
[Edited on 17/4/07 by Paul (Notts)]
Fred W B
posted on 17/4/07 at 04:24 PM Reply With Quote
No disrespect (looking at your car) but the paint will be going!
Fred W B
ned
posted on 17/4/07 at 04:55 PM Reply With Quote
nice one fred, when finished you'll have to do a top gear style epic road trip to the uk, how about stoneleigh next year? I'm sure enough people on here could put you up en route
Ned.
Fred W B
posted on 17/4/07 at 05:15 PM Reply With Quote
Nice idea Ned, but it would be a hell of a long way to go with 80 mm ground clearance
Plus it's a lot of work to go yet:
finish body pattern
make body molds
make body
mount body on proto chassis
make real suspension
make real chassis
build up car for real
get it on the road
so more like 2 to 3 years to go?
Fred W B
DIY Si
posted on 17/4/07 at 06:21 PM Reply With Quote
Excellent find there sir! Good to see some luck going you're way. Only a few minor bits left to do.......
Sun Tzu, The Art of War
