Jubal
posted on 21/4/07 at 06:35 PM |
Hole in airbox
The hole in the airbox as per the pic below ended my day early at Elvington today. Under load it now won't pull more than 6k revs. Sat in the
paddock it revs just fine.
What do you reckon has happened? And should I just replace it with a sausage filter?
Sorry if this is a numpty question but I'm no mechanic and am learning as I go.
posted on 21/4/07 at 06:41 PM |
maybe vibration, check that nowt has fallen into the carb! And i would use a sausage filter myself, maybe hooded if it doesnt sit nice out of the
bonnet (ie air ducted to it)
posted on 21/4/07 at 06:43 PM |
Didn't notice any backfires, did you?
PAUL FISHER
posted on 21/4/07 at 07:00 PM |
Hope you have not done any damage to the engine,bent any valves,those big bits of plastic pipe must have gone somewhere,it does not sound good that it
won't rev over 6000rpm on track,I think it should not make that much difference to it reving out with the hole in the airbox,have you tried to
driving it since with the airbox completely removed? to ensure there is no engine damage.
Jubal
posted on 21/4/07 at 07:13 PM |
Nope, no backfires. The piece that blew off lodged itself in the carb, it was one piece, nice clean break.
Cheers for the pointers. I'll get a sausage filter and chop a hole in the bonnet
Jubal
posted on 21/4/07 at 07:19 PM |
Eurk I'll whip it off and check tomorrow before spending any cash on filters.
smart51
posted on 21/4/07 at 07:22 PM |
Have a look at the airbox pictures in my photo archive. It flows air quite nicely. The plumbing bends that you have used have 90° corners and will
strangle airflow.
A foam filter isn't too bad but can be noisy at full throttle.
posted on 21/4/07 at 07:57 PM |
As Chris says, I would be tempted to stick with the original airbox. Just remove the 90 degree extensions and fit the box back on. You may have to cut
a hole in your bonnet though and fit a bonnet bulge but that's not too difficult. Better power and quieter too.
Phil
higgsti
posted on 21/4/07 at 10:05 PM |
i would say that because of the crack in the airbox your getting to much air in causing it not to rev(fuel air mixture too lean)if you do put sausage
filter on you would need to re jet the carbs
tks
posted on 21/4/07 at 11:09 PM |
yupsz thats it...
in fact i guess that for cilinder number 1 its easyer to pull using the new break in cilinder 2 i wouldn't run it without a filter anyway.. the
bad running is surly because its out of balance...
Tks
ReMan
posted on 21/4/07 at 11:17 PM |
quote: Originally posted by chris mason
why not just fit the airbox as it should be? cheaper than a sausage filter and probably gives you more power than one too!!
Chris
Fairly sure you need a bonnet with a bulge to do this.
IIRC thats why I have one.. as I wanted to fit th 'blade box
[Edited on 21/4/07 by ReMan]
mad-butcher
posted on 22/4/07 at 07:42 AM |
Isn't the bulge available as a seperate item or wasn't it modeled off kia sedona
Tony
RazMan
posted on 22/4/07 at 08:22 AM |
Just a thought - did it shatter due to a stone hitting it?
Raz
posted on 22/4/07 at 09:13 AM |
Fireblade airboxes fit either way up don't they? You shouldn't need too much of a bulge with it straight on the carbs. You could cut the
bonnet and just have a bit of the box showing through if you're already on the road.
ChrisGamlin
posted on 22/4/07 at 01:43 PM |
Yep, as long as the airbox doesn't foul the engine cradle etc, it can be mounted in reverse orientation to where it is on the bike, ie the same
way as it is now in the pic above, so the main body points down towards the gearbox.
Jubal
posted on 22/4/07 at 02:51 PM |
Thanks for the pointers all. I'll try with the original airbox before going further. Raining all day here today and a list of trackday pennance
chores have hampered any testing.
jack trolley
posted on 22/4/07 at 03:23 PM |
Are those pipes plumbing bends?
If so, plumbing waste pipe has a Max. Temp. of 50-60C.
Under bonnet temps. can often reach that range.
Also petrol vapours may be corroding the bends.
Jubal
posted on 22/4/07 at 04:49 PM |
Hehe. They've lasted over two years! Nice locost way to avoid cutting the bonnet by the guy who built it.
I've just binned them and quickly refitted the airbox. I now need a dry day to test. Here's hoping.
ReMan
posted on 22/4/07 at 06:39 PM |
So did the bonnet fit?
Jubal
posted on 22/4/07 at 07:15 PM |
quote: Originally posted by ReMan
quote: So did the bonnet fit?
No way! It needs a dirty great big hole making in it It's gonna look hideous but holes are cheap to make!
Jubal
posted on 24/4/07 at 06:43 PM |
The car works just fine with the airbox back directly on the carbs. Revs hard throughout the range. No apparent ill effects.
What I've discovered is that the engine will not rev out without static air at the carbs. A big thanks to everyone, especially those who
u2u'd with advice and offers of help etc.
It's bl**dy ugly with a hole in the bonnet mind! Anyone have some edge trim knocking around? Or a bulge?
