Author: Subject: Did anyone buy one of the cheap fans?
Guinness
posted on 28/4/07 at 06:15 AM Reply With Quote
From this thread?
http://www.locostbuilders.co.uk/viewthread.php?tid=55643
Did they work, and are they pull or push?
Mike
graememk
posted on 28/4/07 at 06:23 AM Reply With Quote
look like pull to me, ie inside engine bay not infront of the rad
posted on 28/4/07 at 06:50 AM Reply With Quote
id say push, looks like it should spin clockwise from the blade trail.
Guinness
posted on 28/4/07 at 07:02 AM Reply With Quote
LOL Should have done it as a poll!
50/50 so far!
Mike
theconrodkid
posted on 28/4/07 at 07:21 AM Reply With Quote
looks like a fiat one,they go behind rad
who cares who wins
pass the pork pies
locoR1
posted on 28/4/07 at 07:27 AM Reply With Quote
I would have to say pull, you wouldn't put a big fan housing in front of a radiator it would block half the rad off!
That's 3-1
Dave...............
rayward
posted on 28/4/07 at 07:45 AM Reply With Quote
designed as a pull, but worked pretty well both ways by reversing the connections
Ray
big_wasa
posted on 28/4/07 at 07:49 AM Reply With Quote
standard Metro item.
Part number PGG10019 PETROL from 1991 to VIN number BD110565
Wired mine in pull mode and moves plenty of air
Steve @ sVc
posted on 28/4/07 at 07:53 AM Reply With Quote
Look at the fan blades from the rad side,
If they are convex its a rear mounted pull fan, if concave , a front mounted push fan.
Remeber "Budget" fans have been around for a long time -
see www.s-v-c.co.uk & we will have an even lower-cost fan @ Stoneleigh. This will be, like the one shown here much deeper than the modern designed fans, so make sure you have lots of space between the rad and the engine.
Regards
Steve @ sVc
Guinness
posted on 28/4/07 at 08:00 AM Reply With Quote
Thanks Guys
Just bought one and will see how I get on.
Steve @ SVC, the £30 plus P&P looks a great unit. Don't think I could justify the £80 in petrol that it would cost me to drive to Stoneleigh and back!
Mike
Next thing, I have a thermostatic switch in line to the fan, how do I wire in an overide switch, in parrellel right?
dave1888
posted on 28/4/07 at 08:52 AM Reply With Quote
They are for sale on ebay at BIN £7 + £7 for postage, see linky.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=014&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=330113676090&rd=1&rd=1
bodger
posted on 28/4/07 at 08:57 AM Reply With Quote
Paid £15 for mine at local breakers & thought I'd got a good deal. Bit sick now I've seen them on ebay, anyway still happy with it, looks like it'll do the job.
MkIndy7
posted on 28/4/07 at 10:05 AM Reply With Quote
Maybe i'm missing something but if the direction of airflow is through the RAD it shouldn't matter which side it is mounted... whatever the fan pushes out of 1 side it must have pulled from the other?
Or is it all to do with high and low pressure air sp one had a better cooling effect?
martyn_16v
posted on 28/4/07 at 10:46 AM Reply With Quote
It'd be alright as long as you were stationary, but as soon as the car starts rolling you're not going to be doing anything useful by trying to push incoming air back the way it came, a bit like piddling into the wind
MkIndy7
posted on 28/4/07 at 11:10 AM Reply With Quote
Weeee! yeh I under stood that bit just forgot to add it.
Was more meaning if you had a puller fan that was designed to go behind the rad and pull through it, if you flipped it over completely and mounted it on the opposite side would it not become a puller (although that wouln't work if it had a cowl)
ernie
posted on 28/4/07 at 05:23 PM Reply With Quote
It`s a push or pull, I bought one on ebay for race car very powerfu,l not bad for £6.00 plus postage
posted on 3/5/07 at 08:59 AM Reply With Quote
so how come fitting it behind the radiator doesn't block the rad off then?
It makes no different with the cowl if it is in fornt or behind.
Whether you fit it in front or behind depends on the fan blades -they are optimise to worj better in one direction but usually for our purposes doesn;t matter as long asthe motor is happy to spin both directions, and usaully they do.
bodger
posted on 3/5/07 at 08:57 PM Reply With Quote
Anyone know where you can buy the connectors from for these fans? (Apart from trawling the scrappies, I'd rather get a new one).
