Author: Subject: fiesta distributor
uglyelliot
posted on 28/4/07 at 04:27 PM Reply With Quote
fiesta distributor
need some advice. I've got an electronic dizzy off a fiesta intending to fit it to an xflow 1300.
got coil and some loom with it
Q: there is a 1.7k resistor near the coil-what is this for?
How can I tell if the coil needs a ballast resistor?
it's stamped '12V' with 1.4 ohms across the terminals.
confused after all I've read.
auzziejim
posted on 28/4/07 at 06:25 PM Reply With Quote
im sure none of the valencia fiestas had a ballast resistor i know the dizzy i fitted to my mk2 escort needed a 12v supply.
james
posted on 28/4/07 at 06:55 PM Reply With Quote
Probably a radio suppressor, wired to the positive terminal and mounted so it earths?
Macbeast
posted on 28/4/07 at 09:05 PM Reply With Quote
If it's stamped 12V, it shouldn't use a ballast resistor.
uglyelliot
posted on 29/4/07 at 11:23 AM Reply With Quote
thanks all the info sounds righr
