Dale
posted on 29/4/07 at 12:15 AM |
Different attempt at fenders /aero
An attempt at a different style with cues from the 55 maserati 250 streamliner.
The nose has to be changed as I did not touch it yet and it will need a front to the front fenders. The backs will look better capped and curved over
the tire, the fronts would be open at the top but maybe have a small cycle fender over the top- but only if needed by law. An alloy air diffuser at
the back would fit in nicely to fill the gap at the bottom of the fenders/fins. Either that or take about 2 to 3 inches out of the back fenders.
Dale
webshots pics at
http://rides.webshots.com/album/96933615lXyang
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
Dale
Dale
clockwork
posted on 29/4/07 at 06:43 PM |
2p. As much as I like the morgan aero8 look you were going for, it seemed a shame to copy something current. This on the other hand (to my eye)
looks great, a style that will be totally your own has to be better surely?
Just one question. Are you going to have a struggle getting in over those sills? What about anything with a skirt
Dale
posted on 29/4/07 at 09:43 PM |
If I go this route, I would put a door of some sort in with a step when its opened. It would have to probably open forward and up from the scuttle
area or so.
Dale
Dale
Dale
posted on 30/4/07 at 02:09 AM |
more bonnet line and infront of the front wings
Dale
Dale
posted on 30/4/07 at 02:10 AM |
Dale
Doug68
posted on 30/4/07 at 08:28 AM |
My nickel on the subject...
Over all I like it and its great that it'll not look like yet another 7 however I'd toss the crusty old MG lights and replace them with
ones from the new Mini which I think would look good and can be had cheap from eBay.
Also at the front I think the way front fender curls under will generate lift as air gets trapped under it.
[Edited on 30/4/07 by Doug68]
MustangSix
posted on 30/4/07 at 03:27 PM |
I like it and think you're on the right track. Better than the Aero 8 idea, IMO.
I would lean toward rounded edges and roll the body work under the car like the inspirational car. I realize this is just concept, but flat 90 degree
panels won't look right with the curvy body work you have on the rest of the car.
I can't tell from that view, but I'll bet if you look at the car from the side and squint a bit, you are not too far off the profile of an
XK120 roadster.
[Edited on 30/4/07 by MustangSix]
Mr Whippy
posted on 30/4/07 at 03:43 PM |
reminds me off...
Dale
posted on 30/4/07 at 03:51 PM |
Just on the smaller scall though Mr Whippy. As well as bit slower.
Thanks for the comments- I have been toying with different front ends as I understand there will be some lift on the front as it sits right now.
Some of the racing morgan +4s have air dams on the front which dont look too bad and are still vintage looking.
I dont really like the mini tail lights for my app- To me they look too new and my car is being registered as a hot rod mgb(already titled in my
name.)
I had not thought of curling it under on the sides but was going to do the top edge to some extent but I like the idea and should have thought of it
myself- but did not. So far as it sits the entire sides could be done in sheetmetal/alloy as it has no complex curve to speak of. The front from
the wheel line up I imagine would have to be glass.
Dale
Dale
Dale
posted on 5/5/07 at 01:10 AM |
TR3 ish
I think I have come up with a back I like, will just have to flair the edges to get a bit more wheel clearance. When I stepped back it reminded me
of a tr3 rear wing. The sides still need a big radius - I am thinking around a 2 inch rad top and bottom for the side.
Dale
Dale
posted on 5/5/07 at 09:00 AM |
Not really relevant but
I went to Hucknall on Thursday and there was a TR3 there in Old English White and it looked beautiful.
