Author: Subject: How long is your dipstick?
MK7
posted on 15/5/07 at 07:30 AM Reply With Quote
I've heard that the different pinto engines have dipsticks of different lengths. I've posted a 'Wanted' add for a replacement for my 1800 SOHC and would be interested to know what the different lengths are ?
Anyone up for measuring theirs and posting the results here?
ditchlewis
posted on 15/5/07 at 07:47 AM Reply With Quote
the full length.
i believe the top level of the oil in the sump remains the same but the volume is maintained by the but on the side. my 2.1 SOHC has a normal one.
but i could be wrong and stand to be corrected
Ditch
Bluemoon
posted on 15/5/07 at 07:59 AM Reply With Quote
If the above is correct, you will need the to measure the length of the tube as well as the dipstic length, since ford may have changed this depending on clearance requirments for injection/noninjection etc etc...
Myke 2463
posted on 15/5/07 at 08:14 AM Reply With Quote
OIL LEVELS
Why dont you drain the oil out and refill withe correct amount then mark the dipstick to show the new level.
miserableoldgit
posted on 15/5/07 at 09:59 AM Reply With Quote
Dipstick
I asked my wife this question; her reply was "About 5' 9"!).
Is she trying to tell me something?
Youth and vitality are wasted on the young
MK7
posted on 15/5/07 at 10:01 AM Reply With Quote
I'm going to have to remove the sump to get the broken dipstick out, it snapped off right at the top of the tube.
Seeing as the tube on mine hasn't changed it shouldn't matter about the length of the dipstik?
The two dimensions that would be of interest are the overall length and the length from the bottom to some aspect that determines how far into the tube it is allowed to go.
NS Dev
posted on 15/5/07 at 10:54 AM Reply With Quote
pull the whole tube out of the block, much easier than dropping the sump. Knock the dipstick out and loctite the tube back into the block again
andyharding
posted on 15/5/07 at 01:24 PM Reply With Quote
I wonder who started this rumor
Bluemoon is cock on. The injection engines have a longer tube to clear the inlet manifold so the dipstick has to be longer to keep the oil level the same.
MK7
posted on 21/5/07 at 09:30 PM Reply With Quote
My dipstick measures 468mm from the tip of the dipstick to the top of the white plastic stopper.
I tried to pull the tube out but couldn't.
The sump gasket needed replacing anyway due to a leak...
Anyone else up fo measuring theirs?
Anyone got a spare one ???
