Slater
posted on 19/5/07 at 07:36 PM |
Fitting Floor - use sealant or not?
Hi
I am at the stage of riveting the chequer plate floor, the guys at MAC#1 have recommended not using any sealant, so any water can drain out easily.
But after reading some build diarys I notice that many people do use a sealant.
Comments please, pros/cons, any advice welcome ....
Keith.
auzziejim
posted on 19/5/07 at 07:54 PM |
i used a pu sealant and dont regret it one bit. over the last few weeks my car has been at work so i could do some work on it and when sitting outside
the days it rained (torrentially some days) it dried out suprisingly quickly so drainage is not an issue but the sealant will act as a rust prevention
as water ingress around the rivets and holes in the chassis can/will begin the tin worm invasion.
bigrich
posted on 19/5/07 at 08:04 PM |
Hi Keith
I used foam tape on my chassis before i fitted the floor pans this does provide a seal but also allows water to seep out over a time due to being
slightly porous.
I did think that it was part of the kit, but may be wrong, as i did request it from them. check your kit boxes to see if you have a roll of it. if not
then i would seal it but its not strictly necessary![](http://locostbuilders.co.uk/upload/a560952-worX 031 (Small).jpg)
craig1410
posted on 19/5/07 at 08:53 PM |
I would say seal the water out of the joints because once rust starts in the seams you will never get rid of it. If you need drainage then drill some
holes and fit rubber grommets.
I welded my floor and then poured thinned etch primer into the joints and let it run through. I then dried this thoroughly and did the same with gloss
black Dulux weathershield. Once that had dried I did all the seams with body seam sealer and then repainted with black weathershield. Should keep the
tin worm out!
Craig.
Avoneer
posted on 19/5/07 at 08:57 PM |
Seal any panels you attach with some form of PU or silicone.
Will help prevent rattles.
Pat...
Avoneer
posted on 19/5/07 at 09:13 PM |
And as said above, drill a couple of 8mm holes in the back corners behind the seats to let any offending water out.
Pat...
Slater
posted on 19/5/07 at 09:24 PM |
I think I'll put some bathroom type clear silicone on the tubes just before fitting the floor. I was thinking about the rust prevention thing
and keeping water out of the rivet holes. A few drilled holes in the corners of the floor can let out any water.
whitestu
posted on 19/5/07 at 09:28 PM |
I sealed mine with PU, but I haven't been out in the rain yet!
I can't imagine it matters much either way, but then I've been drinking.
Stu
Mark Allanson
posted on 19/5/07 at 10:32 PM |
Bathroom sealant cured through acetic acid evaporation - so you have steel, aluminium and a moderately strong acid....
Buy some tiger seal, £2 more expensive, but worth every penny
caber
posted on 19/5/07 at 11:35 PM |
Aluminium + steel + water makes a good battery with the Aluminium being eaten. Look at old Discos and Rangies particularly around the door bottoms
where water settles.Ally worm will be present and if you get the skin off the steel will be pretty rotten too!. I would use PU and paint the steel
with something thick and sticky first to keep them as far apart as possible. Ally rivets will be best, if the other precautions work it will remain
dry where they touch steel if you use the closed end type.
Caber![](/images//smilies/wink.gif)
