Author: Subject: Bushes
ChrisW
posted on 30/5/02 at 04:32 PM Reply With Quote
Bushes
My second question today...!
What bushes have people used for front wishbones? In the book it mentions a Triumph Herald but there is more than one bush on a car!
Other complication is that the ends of my wishbones are 40mm wide, rather than 36mm in the book so I'd need wider bushes anyway.
Any ideas please??
Chris
My gaff my rules
Jon Ison
posted on 30/5/02 at 05:13 PM Reply With Quote
have you got accsses to a lathe ? if so make your own, will get spec of material from work for you, i had to pay for it, total cost £7, and in green to, match's the car, i could have had other colours though, let me know if you want material name / spec, will get it for you.
chrisg
posted on 30/5/02 at 05:16 PM Reply With Quote
Hi Chris,
The bushes in the book are Herald/Spitfire front wishbone bushes.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
ChrisW
posted on 30/5/02 at 08:43 PM Reply With Quote
Chris - how wide are they? Will they be ok in my 40mm tubes?
Jon - I don't have a lathe myself but if all else fails...! Any chance you can cut them? Drink in it for you!
Chris
My gaff my rules
Hornet
posted on 31/5/02 at 08:27 AM Reply With Quote
i have access to lathe, if you post spec dimensions etc, i can get extras made at same time!!
ChrisW
posted on 31/5/02 at 03:04 PM Reply With Quote
You're just after Jon's drink arn't you!
Anyway, Jon, if you can get hold of the material that'd be great. It needs to be the same as in the book just 40mm wide instead of 36mm. That is unless anyone knows where to get them ready made?
Cheers, Chris.
My gaff my rules
Jon Ison
posted on 31/5/02 at 05:18 PM Reply With Quote
ok boys, will be back in shop wednesday, will get spec and post it on here, i have now covered 500 miles with no problems, was a bit nervous at 1st, kept junping out and checking, but they aint moved a thou, infact other than one broken front cycle wing stay, (which i realise i made to lightweight anyway) nothing as fell off at all, it takes a while to get confidence in the car but its coming....
Hornet
posted on 1/6/02 at 07:38 AM Reply With Quote
I'm a typical Scotsman, free drink WHERE?
ChrisW
posted on 1/6/02 at 05:44 PM Reply With Quote
Free drink for whoever can sort these bushes out for me (or breakfast in the case of the W London guys!) Who's it going to be??
Chris
My gaff my rules
Jon Ison
posted on 5/6/02 at 05:40 PM Reply With Quote
Rite here is the info.........
the material is called "Oilon"
it can be supplied in loads a coulours, i had green, it comes in any Dia from 10mm to 100mm,
i used 25mm and turned it down in a lathe, the cost as gone up though, 25mm Dia is now a massive £10 per metre, and can be had from ......
Direct Plastics.....01142 560889. makes you wonder how much "pro flex" are makin dunnit ?
there as promised. Jon
interestedparty
posted on 5/6/02 at 06:24 PM Reply With Quote
This might just provide the excuse I've been looking for to buy a lathe. My excuse for buying a plasma cutter was that Machine Mart had an ex-demo one for a couple of hundred off, too good to miss.
John
I just love acquiring tools!
posted on 5/6/02 at 08:23 PM Reply With Quote
Oooh...
...I've always wanted a plasma cutter
(I hate hacksawing sheet metal).
Now I'm jealous!
andybuff
posted on 10/6/02 at 08:05 PM Reply With Quote
found this info on the oilon material usod in the bushes 25 TIMES STRONGER THAN PHOSPHER BRONZE BUSHS!!!! that should do the trick http//www.nylacast.com/grades/oilon/htm
ChrisW
posted on 11/6/02 at 12:53 PM Reply With Quote
Ok then - who's going to offer to cut it for me on their lathe?
Chris
interestedparty
posted on 11/6/02 at 02:51 PM Reply With Quote
I had a look at the web site mentioned. It said the Oilon material was self lubrication and 25 times more wear resistant than phosphor bronze. What I doon't see is how that makes it more suitable as suspension bush material. The stuff isn't supposed to slide around, it's supposed to deflect in a controlled manner.
John
Jon Ison
posted on 11/6/02 at 04:15 PM Reply With Quote
i think the £10 / Mtr makes it suitable, plus the fact that its up to the job, the self lube bit does help when your pressing them in, allso helps when your turning them on the lathe, nothing cast in stone here, just shareing info......
interestedparty
posted on 11/6/02 at 08:11 PM Reply With Quote
Good point, Jon.
John
F*** Authority
posted on 11/6/02 at 09:52 PM Reply With Quote
im currently restoring a '67 GT6 which has the same wishbones as a herald, i will measure the wishbone eyes and post the dimensions tomorrow.
F*** Authority
posted on 12/6/02 at 05:58 PM Reply With Quote
the centre tube in herald wishbone bushes are 37mm long
PAULA12
posted on 7/10/02 at 12:41 PM Reply With Quote
PLASTICS 2 INDUSTRY also supply material for the bushes - they seem very competitive on pricing and availability - they do a low cost alternative also.
They have a freephone number 0800 0184477
johnston
posted on 7/10/02 at 07:15 PM Reply With Quote
wot sort of lathe u usin a metal 1 or wood???
and wot bout the metal tube in the middle??
Graham G
posted on 9/10/02 at 07:16 PM Reply With Quote
How much longer r u guys making the "metal bit in the middle" than the plastic bush ? (I assume u make it longer other wise the bush gets nipped up)+ wot lube do u use to stop it squeaking?
