Author: Subject: pinto throttle body conversion
macspeedy
posted on 29/5/07 at 12:26 PM Reply With Quote
i have decided to look at changing to throttle bodies to improve performance and fuel consumption, i am not sure which bike throttle bodies are best to use, i have a flowed head standard valves balanced bottom end and fast road cam. also how much would a set of 45's in good condition be worth?
thanks in advance
Mac
[Edited on 29/5/07 by macspeedy]
View User's Profile View All Posts By User U2U Member   macspeedy 's Aim
flak monkey
posted on 29/5/07 at 12:34 PM Reply With Quote
A good matched pair of 45's will fetch around 300 on ebay.
Sera
https://www.facebook.com/sera.jay666
se7ensport
posted on 29/5/07 at 02:07 PM Reply With Quote
Originally posted by macspeedy
i have decided to look at changing to throttle bodies to improve performance and fuel consumption...
Do you have somone in mind to make the manifold? I'm looking for somone to fabricate a pinto to GSXR one without much success.
Alex
se7ensport
posted on 29/5/07 at 03:07 PM Reply With Quote
Originally posted by CaLviNx
Hi
I'm making manifolds for a few people to almost any specs.
You have U2U.
Alex
caber
posted on 29/5/07 at 05:29 PM Reply With Quote
Another u2u on its way!
Caber
flak monkey
posted on 29/5/07 at 05:35 PM Reply With Quote
So you want TBs and not carbs then? Of course with TBs you will need the injection system and megasquirt to control it. If not you want carbs, then GSXR or R1 carbs are good apparently.
You probably want to be looking for a set of 38 or 40mm throttle bodies. Not sure what bikes to look at though to be perfectly honest.
Sera
