Author: Subject: Spark??
ibakes
posted on 1/6/07 at 07:55 AM Reply With Quote
Spark??
Morning
Is there any reason why when the spark plug is fitted to the engine and I attach the timing light to a plug lead the light will not be overly reliable? sometimes not work at all, or miss every other spark.
but when the spark plug is resting against the block the timing light is perfect?
Having trouble making it run nice at the moment
posted on 1/6/07 at 08:08 AM Reply With Quote
yes. when the plug is inside the engine, the spark is attempting to jump the plug gap in a compressed atmosphere that has fuel vapour. I believe that is less favourable than when it is resting on the block when all it needs to do it jump across air at atmospheric pressure.
The lamp is triggered off by the spark so the spark is not occuring.
Over fuelling may result in petrol shorting out the spark plug contacts so no or intermittent spark.
What do the plugs look like colourwise?
ibakes
posted on 1/6/07 at 08:14 AM Reply With Quote
The plugs are sooty, and I know I’ve got to get the fuel down, but this also happens when the MS unit is not attached.
Defiantly food for thought tho
Agriv8
posted on 1/6/07 at 09:35 AM Reply With Quote
Assume you are using a coil pack of some sort ( which one ? )
I have 3 timming guns 2 of which would not work with my waisted spark coil packs ! on the v8
A general consensus is that.
1 cheep timming guns with 'No timming advance features' are Ok.
2 Middle of the road guns with 'timing advance' seem to be problematic.
3 Expensive timming guns with 'timming advance' seem to be OK
Regards
Agriv8
ibakes
posted on 1/6/07 at 11:15 AM Reply With Quote
Appologies and using edis 4 unit
and think its snapon with timing advance (borrowed from me brother)
rusty
posted on 1/6/07 at 11:16 AM Reply With Quote
Are the plugs new and gapped correctly also are the leads and connection in good condition, is the coil pack well earthed.
Agriv8
posted on 1/6/07 at 11:21 AM Reply With Quote
MMM thats a catogory 3 gun
Have you got the pickup facing the right way ? ( the clip that you place round the ign lead ) there should be an arrow this needs to point to the spark plug.
regards
Agriv8
ibakes
posted on 1/6/07 at 11:55 AM Reply With Quote
Not new but seem to give a nice spark when out of the engine
but the coil pack is loose where ive been playing around so probably not...
regards
Agriv8
Have to check when I get home
ibakes
posted on 1/6/07 at 05:27 PM Reply With Quote
Right tried all thoes and pretty much the same really still it fires up
runs like a bag of poo but hopefully that is just due to overfueling (only just to get it started) as not tuned it at all must get the o2 sensor reading correctly
thanks for all the help
[Edited on 1/6/07 by ibakes]
DarrenW
posted on 7/6/07 at 11:31 AM Reply With Quote
Snap on advance timing light worked well for me. Ive got an old one with digi display. Only thing i had to remember is that it reads double due to being wasted spark, apart from that was good.
