liftarn
posted on 9/6/07 at 11:54 AM |
Size of Suziki Swift GTi engine and gearbox
Hi!
I'm wondering if anybody have the dimentions of the Suziki Swift GTi twin cam engine and gearbox? I have seen if fitted in the front of a Mini
and I was thinking about using it in a bullnose SAAB 96...
goodall
posted on 9/6/07 at 05:23 PM |
how about staying with the longitudinal layout and use a audi V6 and gearbox? would mean less chassis mods...
or do you have your heart set on a suzuki engine?
CaptainJosh
posted on 9/6/07 at 06:27 PM |
Brilliant engine, I have one in my garden destined for my locost
When it comes to power to weight ratio of an engine it doesn 't come much better than the suzuki gti engine ( unless you go bike engine of
course )- and they still have loads of tuning potential.
I'd check www.16vminiclub.com forum for the dimensions of the engine AND gearbox.
-Josh
liftarn
posted on 10/6/07 at 08:19 AM |
If it was a longnose 96 I could do that (or the classic SAAB 900 turbo), but space is very limited in the bullnose 96.
This is how the 900-engine would fit in a bullnose 96:
Not very well...
I have been reccomended a longitudinal mounted SAAB 9000 Aero engine mated to a BMW 525 gearbox and rear axle. That would indeed require some major
chassis mods (not to mention how wide wheel arches I'd have to get).
At http://www.lowbudgetrides.com/forum/viewtopic.php?t=69 you can see how a 900 engine can be made to fit in a longnose 96 (with the radiator in the
trunk). It's a tight fit.
I'm not dead set on the Suzuki engine, but it has some major advantages. It's quite easy to find at reasonable prices (always a good
point), it small (so it fits), it's low weight (so the car doesn't get front heavy) and the track width is quite simmilar (altough I
probably need to modify the drive shafts anyway).
goodall
posted on 10/6/07 at 10:36 AM |
ah sorry to young too know there was a short and long nose 96
only other thing i could say is there the width in the bay for transverse between the chassis rail?
http://locostbuilders.co.uk/viewthread.php?tid=68069&contribmess
age=none as you can see in the pics there the transverse bay is very wide when you see an engine mounted longitudinally
liftarn
posted on 10/6/07 at 11:39 AM |
Well, the bullnose was replaced by the longnose in 1964 so it's not a recent model.
The 96 is wider than the Mini (1.57 m vs 1.40 m), but the wheel arches are quite wide. That's why it would be good to have the measurements.
(notice that the radiator is placed behind the engine)
I could ofcourse make a custom front frame, but that would make it more difficult.
Some people put the SAAB 99/OG900 spindles on the 95/96 wishbones so I could get brakes to match the engine.
The first SAAB, the 92 from 1949, actually had a transverse engine.
[Edited on 10/6/07 by liftarn]
