Author: Subject: cossie type (108mm) cv joint bolt threads??
NS Dev
posted on 18/6/07 at 01:04 PM Reply With Quote
anybody know whether the 2wd cossie driveshaft bolts (6 per lobro joint) are 3/8 UNF or M10 x 1.25. I have lost me thread gauge and they look the bloody same to me!!
I know the 100mm ones are m8 coarse but the 108mm ones are approx 10mm and certainly not m10 coarse!
andyharding
posted on 18/6/07 at 01:05 PM Reply With Quote
Going to be metric I'm sure
NS Dev
posted on 18/6/07 at 04:11 PM Reply With Quote
no doubt, thinking about it I have a flipping 3/8unf tap so can at least eliminate that one, and I know its not m10x1 as I have tried a brake fitting in the drive stub threads.
then it'll be ordering a lovely m10 x 1.25 tap. In fact hope it is as I have drilled the holes to suit m10 x 1.25 which will be a problem if they are 3/8 unf!
posted on 18/6/07 at 05:24 PM Reply With Quote
Is this for the grasser or a cunning plan to prevent any more breakages on the Locost?
NS Dev
posted on 18/6/07 at 05:40 PM Reply With Quote
ahhh!
nah this is for the grasser, now the locost is in one piece hopefully for more than 5 minutes I am trying to decorate my bathroom and build the grasser!
goodall
posted on 18/6/07 at 06:07 PM Reply With Quote
if the cups the same spec as an audi 100, which uses the same lobo shafts, it would be standard M10
NS Dev
posted on 19/6/07 at 11:59 AM Reply With Quote
checked last night, they are "nearly" 3/8" unf, it goes 3 threads in then stops.
They are coarser than M10 x 1 and finer than M10 x 1.5 ...................
so M10 x 1.25 fine it is then!!
