Author: Subject: Rover Clutch master cylinder diameter
stevec
posted on 26/6/07 at 12:31 PM Reply With Quote
Does anyone know the usual clutch master cylinder bore diameter used with concentric clutch slave cylinders?
I need to match a master cyl. to a Rover concentric slave cyl.
Also has anyone got a link to a threaded fitting so I can replace the quick release standard connector on the plastic pipe with one I can connect to a metal pipe.
Cheers.
Steve.
posted on 26/6/07 at 01:47 PM Reply With Quote
Oddly enough I just spoke to Burton about clutch master cylinders for their universal concentric clutch slave, and they suggested 0.7". The Rover one may well be different though.
Vdub boy
posted on 26/6/07 at 07:49 PM Reply With Quote
I was running the standard rover master cylinder on my dax (off a sd1) that had a bore of .625 I think, however I've changed to a girling .875, as for the threaded connection - I had to have a goodridge hose made up
HTH
Leigh
posted on 27/6/07 at 06:44 PM Reply With Quote
Post 1999 Rover 45 uses a more conventional master cylinder than the 75.
I think it is about 0.7" bore.
