zxrlocost
posted on 20/7/07 at 07:03 PM |
893 fireblade loom wiring diagram
Hi
I have a 919 engine but the loom is from a 893
it all works fine however Im just wiring up some last bits and pieces and think some colours are different
has anyone got a copy of an 893 loom diagram they could email me covers@homecall.co.uk
thanks chris
macdave69
posted on 20/7/07 at 07:58 PM |
i have a black and white copy I can scan in and email to you. I used it in conjunction with a locoblade wiring diagram somewhere on here that has
proved invaluable
Avoneer
posted on 20/7/07 at 08:27 PM |
I've got the haynes manual if you need to me to check anything.
Pat...
maximill666
posted on 20/7/07 at 09:04 PM |
I also have a haynes manual for this year blade, if you still need the wiring diagram I can scan it & email to you.
zxrlocost
posted on 20/7/07 at 09:42 PM |
if someone could just confirm the indicator wires are grey blue and orange before the switch gear please
thaks chris
macdave69
posted on 20/7/07 at 10:25 PM |
grey power in , orange right and blue left power out
Hope it helps
Dave
Andy B
posted on 21/7/07 at 08:27 AM |
You might know this already but the 3 generation of Carbed blades have different ignitor boxes -
All 893 have prefix MWO
919 RRT/v - MASA
919 RRW/X - MASG
You can run any of the engines on an MWO or MASA box but the 893 (MWO) has no input for the TPS and to get the best out of them you should match
ignitor to motor.
The only problem this throws up is if your motor is an RRW/X your 893 loom will not have the pink wire for the imobiliser - you can get round this (if
this is the case) by adding a pin to your ecu plug and feeding it with an ignition switched live through a 3.9v zenner diode. If you need to do this
let me know and I will tell you which pin position to put the additional wire on
regards
AB Performance
zxrlocost
posted on 21/7/07 at 10:38 AM |
thanks everyone
