Author: Subject: what size fuse
graememk
posted on 30/7/07 at 10:14 PM Reply With Quote
what size fuse
should i use on my lamda sensor ?
RazMan
posted on 30/7/07 at 10:27 PM Reply With Quote
A lambda sensor on its own will draw very little current - a 5A fuse should be ample.
Raz
graememk
posted on 30/7/07 at 10:28 PM Reply With Quote
thank you razie
lsdweb
posted on 31/7/07 at 12:05 PM Reply With Quote
Unless it's a heated lambda sensor?
graememk
posted on 31/7/07 at 02:38 PM Reply With Quote
yes its heated
rusty
posted on 31/7/07 at 04:44 PM Reply With Quote
10A should do, put a 10 in and see if it blows, or get a spec sheet for sencor.
lsdweb
posted on 31/7/07 at 05:10 PM Reply With Quote
I'm with Rusty - try a 10 amp on the heater circuit.
RazMan
posted on 31/7/07 at 06:12 PM Reply With Quote
10 Amps? Surely a lamba sensor is not going to draw the same as a pair of halogen headlights?
Raz
darrens
posted on 31/7/07 at 08:40 PM Reply With Quote
5A will easily cover lambda sensor heater cct
