Author: Subject: Pinto thermostats
flak monkey
posted on 2/8/07 at 05:04 PM Reply With Quote
Pinto thermostats
The std one is 88deg, is there a lower one available? Or should I just drill a bypass hole in the normal one?
Sera
http://www.motosera.com
jos
posted on 2/8/07 at 05:11 PM Reply With Quote
yup burton power do lower temp ones
andyharding
posted on 2/8/07 at 05:35 PM Reply With Quote
Why would you want to run the engine cooler? You'll make less power.
mookaloid
posted on 2/8/07 at 07:43 PM Reply With Quote
I was led to believe the opposite was true and that the optimum thermostat for a tuned pinto was the 82 deg - this from my local friendly engineer who worked on my engine which produces over 180 BHP
Mark
jacko
posted on 2/8/07 at 08:34 PM Reply With Quote
I dont have one fitted and it runs at 80deg
TangoMan
posted on 2/8/07 at 09:02 PM Reply With Quote
And will probably also suffer with hotspots around the back of the head.
I would get one fitted (or a blanking plate) as this is known to cause problems with the Pinto.
Summer's here!!!!
flak monkey
posted on 3/8/07 at 05:57 AM Reply With Quote
Mark
Bingo Hence my question. Burtons do sell them yes, but I was windering if the thermostat from another vehicle fits? If so it will save me sticking another order into burtons...
Sera
flak monkey
posted on 3/8/07 at 05:13 PM Reply With Quote
To answer my own question, the fiesta Mk 4 1.25litre stat is an 82deg and fits the pinto housing.
Sera
jacko
posted on 3/8/07 at 07:53 PM Reply With Quote
Its been like it for 3.5 years and had no problems . What problems will happen if i dont fit one ?
Graham
Macbeast
posted on 3/8/07 at 08:04 PM Reply With Quote
Why does the thermostat affect performance (once the engine is up to temperature ) ?
I thought cooling systems were pressurised to allow water temperature to be above 100 deg C, this allowing the engine to operate more efficiently.
I thought the thermostat was to restrict flow of coolant through the radiator until it reaches a reasonable temperature, thus speeding warm up and reducing engine wear.
Edited after reflection
I suppose the pressurisation is to give a greater margin of safety before coolant boils - doesn't mean the engine is running at over 100 dec C
But then, any time temperature is normal and you incautiously take the cap off, the coolant boils so it must be at 100 deg.
even more confused now
confused dot bloke
[Edited on 3/8/07 by Macbeast]
