stevec
posted on 4/8/07 at 12:31 PM |
Turbo 1.8 Kseries Engine in the chassis update
I have now got the engine and box and propshaft in the chassis,
See pics.
Have used a Caterham short sump and pickup pipe with a baffle plate.
Air filter will have to live in the passenger footwell fed by a duct in the side panel but at least I can get cooler air intake temps.
Just the plumbing and wiring and fiddly bits to do.
Steve.
graememk
posted on 4/8/07 at 01:29 PM |
that will make a nice roar in the passenger side footwell lol
cant you feed it into the tunnel ?
clockwork
posted on 4/8/07 at 01:33 PM |
Why don't you push the airfilter up and through the scuttle?
Just a thought.
"Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety." Benjamin Franklin.
"Well if you have nothing to hide, you have nothing to fear" Morons the world over.
Locost/Kit builders info and FAQ website:- www.carbuilders.info
graememk
posted on 4/8/07 at 01:35 PM |
yeah and a k and N style filter where the battery should be
stevec
posted on 4/8/07 at 01:46 PM |
I am thinking that to get cooler air will be the best way to go as the under bonnet air very warm wherever you take it from.
I want to put the battery in the footwell aswell.
The blue hose will be cut to minimal length and a K&N filter fitted. I have to shoehorn a intercooler in aswell somewhere, maybe on the
scuttle.
philipjn
posted on 4/8/07 at 02:58 PM |
Hi Steve,
I am new here and I am building a Locost with a K series 1.6 and I need a few pointers, got my bell housing (from QED) yesterday, already have type 9
box, engine is already out of donor ready to be cleaned, chassis was bought as an unfininshed project of ebay and needs a bit of a cleanup this uses a
full sierra rear assembly. Anyway some questions:
1. Were did you get the engine mounts from?
2. What wiring loom did you use as I am assuming one from a Rover 75, and if so was it difficult? As I have already took the loom out of the donor and
will be staring at wiring diagrams soon
3. How much did you pay for that engine as I want to put one in the next locost I build.
Thanks,
Phil
stevec
posted on 4/8/07 at 03:19 PM |
quote: Originally posted by philipjn
Hi Steve,
Thanks,
Phil
Phil.
I made the engine mtgs myself, I made wooden patterns then made them from steel. The rubber mtgs are the same as Caterham use but I got them for half
the price by finding out what they also fit.
The loom is the Rover car engine loom and I have modified to convert to my car.
The ECU is a special and has no antitheft stuff in it.
Try and get a Caterham sump if you can they give really good ground clearance.
I think "CM" from this site had one for sale.
Welcome to the forum and enjoy your build.
Steve.
philipjn
posted on 4/8/07 at 04:13 PM |
Hi Steve,
Thanks for the reply, I have already bought the sump and Stainless steel manifold from CM a few weeks ago , Wow you made them mounts yourself, do
you still have the plans on how to make them? Also what rubber mtgs did you use and were did you get them?
Regards,
Phil
stevec
posted on 4/8/07 at 04:33 PM |
Hi Steve,
Regards,
Phil
You would be best to make the mountings to suit your own car, there tends to be slight differences.
LINK to mountings
Steve.
philipjn
posted on 4/8/07 at 05:34 PM |
Thanks a lot Steve you've been a great help.
Regards,
Phil
Hammerhead
posted on 4/8/07 at 09:58 PM |
looks great steve, wish I went for the adapted bellhousing instaed of the caterham jobby.
Phil, you may need the longer input shaft type9 from a v6 capri or sierra, you then need to trim 12mm off it to make it fit with a spigot bearing from
caterham. Good luck, it's not the easiest installation.
The k series brotherhood is growing!! KEC's (we must be mad!)
philipjn
posted on 8/8/07 at 07:09 PM |
Hi Hammerhead,
I got a type 9 from a two litre sierra and a bellhousing from QED Motorsport that fits on a short type 9, it came with a rover starter motor spacer
and some bolts. My engine will be getting mounted soon but I need a little help with the mounts (again), I bought the mounting rubber that Steve
recommended but I need some help with the engine mount design (a picture or drawings would be ideal just to show me how they are made) sorry about the
stupid question, hope you guys can help.
Phil
