Author: Subject: Zetec Alternator
posted on 7/8/07 at 02:02 PM Reply With Quote
Zetec Alternator
Here we go, I've searched the forum and read all the threads. Searched Google and eBay along with other kit car sites but am still mightily confused about alternator choice.
My problem as I sure other people have had is the standard zetec one is too big. It doesn't fit the gap under the inlet and there is now an engine mount where it originally sat.
Various japanese, denso, charade micra alternatives have been used/suggested but I'm struggling to see how they are connected via the pulley. Most of them have a V pulley and the Ford systems is a flat mutligroove jobbie. I see on the Sylva site they use a Lucas LRB172 from a Ford Fiasco or Escort. Does anyone know how big the LRB172 is?
Can anyone give me the definitive advice, or point to the right url for connecting these small alternators and is 40amp output enough for my RedTop 25?
I can make my own brackets its just getting the right parts thats puzzling me.
posted on 7/8/07 at 02:20 PM Reply With Quote
look at the pulley end - ther should be a nut holding the pulley on; also a hex keyway in the shaft so hod it as you undo rthe nut.
you have to realise that alternaotr manufacturers make alternators for different car manufactures and models - it would make sens for them to be fitted with different pulleys as per requirement.
lsdweb
posted on 7/8/07 at 02:21 PM Reply With Quote
Coozer
I used the Daihatsu one - just walked into my local motor factors and ordered one with an appropriate pulley to use with my bottom pulley. I bought a bracket from Tiger but would make one / get a better one made locally next time.
Photo here
I don;t suppose there is a definitive answer but this worked for me!
Wyn
neilj37
posted on 7/8/07 at 02:23 PM Reply With Quote
Drop numnuts (dion) a message as he built my MNR which is running a 2l zetec, he maybe able to point you in the right direction.
UncleFista
posted on 7/8/07 at 02:29 PM Reply With Quote
We wondered about that with our Micra alt, then just welded the pulley on Seems central and isn't going anywhere, and at a tenner from the scrappers, if owt goes wrong with it, it gets replaced
Tony Bond / UncleFista
bob
posted on 7/8/07 at 03:17 PM Reply With Quote
I kept the trusty bedford rascal alterantor from my pinto set up and used it on the zetec, removed the V belt pulley and replaced with the multi groove pulley from the original zetec escort set up.
I had to get a sleeve turned down to make the multi groove sit central, no probs so far.
Mole
posted on 7/8/07 at 04:11 PM Reply With Quote
lsdweb, why the toothed pulled are you not using the Zetec flywheel?
posted on 7/8/07 at 04:19 PM Reply With Quote
The 1.8 zetec in the Fiesta XR2i had the bracket on the exhaust side lower down, could you fit the alternator there in your car?
posted on 7/8/07 at 04:32 PM Reply With Quote
My engine came with a huge ali bracket down there with the alternator, pas pump and some over pulley on it. There is an engine mount there now and there is a chassis rail in the way so I can't get it underneath
lsdweb
posted on 7/8/07 at 04:36 PM Reply With Quote
I used the CVH flywheel (lighter) so had to find another location for the crank trigger. That seems to be a common problem for me these days!
Wyn
neilj37
posted on 7/8/07 at 05:35 PM Reply With Quote
Once the batteries on the camera are charged up I'll try and get a photo of mine if that will help
TangoMan
posted on 7/8/07 at 06:18 PM Reply With Quote
I opted for the alternator off a CVH/ DOHC Sierra. This, although not small, fits straight on and has the correct pulley.
One day I may fit a smaller one but this does fine for now and was cheap and new off ebay.
Summer's here!!!!
posted on 7/8/07 at 06:30 PM Reply With Quote
Any idea size wise against the zetec alternator. I've just measured it and its over 6" across!
I'm wondering as well how big the Escort one is as I mentioned above.
big_wasa
posted on 7/8/07 at 08:53 PM Reply With Quote
Escort as sold by Dunnell
big_wasa
posted on 7/8/07 at 08:54 PM Reply With Quote
sierra Dohc
big_wasa
posted on 7/8/07 at 08:57 PM Reply With Quote
Renault 5
posted on 7/8/07 at 10:12 PM Reply With Quote
Cheers B-W
Dunnell one looks canny, can't imagine I can afford it though! Is that the Lucas LRB172 I mentioned above? Recommended by Sylva.
Does the Renault 5 one come with the correct pulley??
TangoMan
posted on 9/8/07 at 10:16 AM Reply With Quote
It was noticeably smaller than the Zetec one but about the same as the one that came off the Pinto.
Summer's here!!!!
