Author: Subject: QQ: How big is your........
t.j.
posted on 10/8/07 at 07:16 PM Reply With Quote
Steering wheel, as i'm positioning the wheel I need to know the outer diameter of a normal wheel for a seven.
I have only the standard wheel from a sierra.
Maybe someone has a XR4i, iS or cosworth wheel diameter?
Thx
Tigger
posted on 10/8/07 at 09:27 PM Reply With Quote
I would say around the 300mm mark.
Although there are lots smaller and a few bigger, I'd say 300mm is about normal.
Go on somebody, disagree
Tigger
Confused but excited.
posted on 10/8/07 at 09:28 PM Reply With Quote
What's 'normal' got to do with a seven?
I'm going with a 12" (not a 300mm, back off Brussels)Mountney, 'cos it was both new and cheap.
Some have larger, some have smaller.
I would also think the ratio of you rack may be an influencing factor.
[Edited on 10/8/07 by Confused but excited.]
Peter M
posted on 10/8/07 at 09:40 PM Reply With Quote
12" and 300mm is more or less the same size.
[Edited on 10/8/07 by Peter M]
my previous cars
my westfield build
t.j.
posted on 10/8/07 at 09:45 PM Reply With Quote
He wants no mm, that's why he says back off brussels
Come on; give up does silly measurements.
Inch; 2.54 cm , pounds; 0.4535 kg, elbow, feet, mile; 1.6 km,
much easier:
meters, and grams
you don't need anymore
RazMan
posted on 10/8/07 at 10:21 PM Reply With Quote
320mm here - about right with a quick rack too.
Raz
graememk
posted on 10/8/07 at 10:42 PM Reply With Quote
i'm using a 10" maybe a bit small
DavidM
posted on 10/8/07 at 10:51 PM Reply With Quote
I've got 11" (oooer missus).
Well somebody had to.
posted on 11/8/07 at 09:13 AM Reply With Quote
I've got 12" (nyah, nyah)
Plenty small enough when you've got a quick rack. Couldn't be any larger, as I wouldn't be able to get my legs under it.
dr-fastlane
posted on 11/8/07 at 02:47 PM Reply With Quote
The one in my car measures 320mm. But I have also a spare one that measures 300mm and I don’t use. Perhaps interesting?:
Greets Roy
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
t.j.
posted on 11/8/07 at 06:23 PM Reply With Quote
Greets Roy
I will U2U
